Dual Point Distributor Points
Posted By randyh 14 Years Ago
34xracer
Posted 14 Years Ago
First Time Poster
First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)
Last Active: 14 Years Ago
Posts: 3, Visits: 11
Yep, it had the rear sump pan, even at that, it was 'modified' (ball peen) for tie rod clearance in the '51. It had the wide-base 2v carb and manifold,the carb is garbage. I was able to salvage the cam (looks stock) and crankshaft (R .020, M .010). The crank is borderline useable as is, or easily ground to the next .010. Motor was so stuck that I had to torch the rods to get the crank outCrying.
Posted 14 Years Ago
Your likely right about it being a 59 (or 60) truck engine,with tack drive. It may also have a rear sump pan. Was is a 4 bbl unit by chance? To bad you can't salvage any of it?
34xracer
Posted 14 Years Ago
First Time Poster
Hi guys. I had to throw in my two cents on this. I just finished tearing down a 292 Yblock that has set in the timber for the past 40 years. It had been put in a 51 Ford convert, and was a half completed custom project that was abandoned by the owner. Anyway, the motor is trash from being full of water, but I was able to get the tach drive distributor out in one piece. It has the FEK-12127-C2 number on it, and is single point. Date code is 6O3, and it's a 14 tooth gear. The fact that it has the dipstick in the side of the block (not the front cover), and casting numbers B9AE, I believe this is a 59 truck motor. So, maybe there is something to the truck tach drive guess? I'm assuming that physically this is the same as the tbird tach drives, just the specs are probably a little different? There was no cable on this, a small cover had been made for the hole.
Unsure
Dennis K.
Posted 14 Years Ago
Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)
Posts: 143, Visits: 451
xxx
In the S/C Dist the straight points have part number FR-151 S and the curved points have FR 152 S stamped on it.
Both have a mfg logo on them "CP", more of a "C sub P", like in a math equation.
Can anyone ID or cross those numbers over to another manufacturer or source?  Trying to help Randy H  out.
Regards,
Dennis
buddy
Posted 14 Years Ago
Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)
Posts: 64, Visits: 413
Thanks for all the advice and information.  I probably need to check the advance curve for sure on my distributor.
buddy
slumlord444
Posted 14 Years Ago
Posts: 1.2K, Visits: 137.8K
The FE  and 289 Ford factory dual point distributors were centrifical advance only  with no vaccum advance. When converting the Y block distributors to dual points using the FE parts you plug the vaccum advance and re curve the distributor accordingly. Been running mine that way since the late '60's.
buddy
Posted 14 Years Ago
I dug out my distributors. My passenger car supercharger dist is FEH-12127-E, date code is 743. It has straight and curved points and a vacuum advance diaphragm assy, but the port is plugged.
I noticed in your earlier post shown above that the vaccum advance was plugged on the FEH 12127 E distributor.  When I bought my 1957 312 it was complete except for the carburetor and the vacuum advace on my COAF 12127-A distributor was also plugged.  I found that baffling and was curious as to what application you would ever plug the vaccum advance?
buddy
Dennis K.
Posted 14 Years Ago
John,
Counted the teeth on the tach drive dist and it is 15.  The 312 S/C count is 14.
Were any of the 368's dual point, or do you think was this converted?
MARVH, thank you for ID'ing the dist and John for the tooth count info.
As I have a 292 converted to Duraspark on the engine, these will go back into hibernation.
Regards,
Dennis
Posted 14 Years Ago
Posts: 3.7K, Visits: 323.4K
Dennis:
I understand the Lincoln distributor will work in a Y block if you put the 14 tooth Y block gear on the Liincoln distrubutor.  The Lincoln has 15 teeth I think.
Dennis K.
Posted 14 Years Ago
marvh (3/3/2012)
Dennis K. (3/3/2012)
buddy (2/29/2012)
The 1960-64 Ford Parts Book lists C0AF-12127-A for a 60-62 292 engine. Somewhere it must of been converted to dual points. On the body near the part number there should be an alphanumeric manufacturing date code. "C0" indicates the decade (C=196X) and model year (0) of the component. A= Full size Ford, and F = Hardware and Accessories Division Product Engineering Office.
Regards,
Dennis
Thanks Dennisfor the explanation and identifying my distributor. Just below the COAF 12127 A is another number Y9KC or O and there was a paper stickershowing it asFoMoCo remanufactured
I dugout my distributors. My passenger car supercharger dist isFEH-12127-E,date code is 743. It has straight and curved points and a vacuum advance diaphragm assy, but the port is plugged.
I have another dual point dist, FEK-12127-C2, date code 6A2, it is a tach drive with straight and curved points. However, I don't think it is a T-Bird based on the drive cable length, a bit over 47".Someone thought Turnpike Cruiser, but from the date code wouldn't that be a bit early? Possibly some race application 312 260 hp LOL or maybe a truck? Anyone know the original application?
I also have one otherdual point, C0AF-12127-A, date code OMB, two straight points. Sounds similar to the one that Buddy was asking about. Coincidence they have the same housing part number or was there an application somewhere?
Regards,
Dennis
Dennis:
In my Master Parts Catalog it shows FEK-12127-C as fitting 57 Turnpike Cruiser 368 engine w/o tachometer not serviced in assembly use FEK-12127-E Confusing as you say that it is a tach drive distributor you have unless the C2 was an update from the original 12127-C model.
FEK-12127-E is for the same engine with tachometer
FEK-12127-C2 is what it reads and it is a cable tach drive.  Any idea why it would have such as early date code, 6A2, Jan 1956 for a 1957 Mercury?
Will this distributor work in a 292 or 312, or is it 368 specific?
Regards,
Dennis
