Ford 332 Crankshaft
Posted By Gary 13 Years Ago
Gary
Posted 13 Years Ago
Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)Turbocharged (72 reputation)
Posts: 72, Visits: 179
I have a Ford 332 crankshaft for sale, may fit others, exc cond, need to move, will ship. Located in Birmningham, AL 35226, email for addnl info gadams2@bellsouth.net or bid on EBAY, starts at $95. no reserve, as of 2-11-12.
Thanks for looking.
Gary
RumbleFish
Posted 13 Years Ago
Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)
Posts: 70, Visits: 1.3K
Gary (2/11/2012)
I have a Ford 332 crankshaft for sale, may fit others, exc cond, need to move, will ship. Located in Birmningham, AL 35226, email for addnl info gadams2@bellsouth.netor bid on EBAY, starts at $95.no reserve, as of 2-11-12.
Thanks for looking.
FE?Crazy
Gary
Posted 13 Years Ago
I don't know what you are asking me ... pls clarify.
Gary
Posted 13 Years Ago
There was a 332 FE (smaller 352 or 390) and a 332 Lincoln Y-Block. Which is it for?
Y block Billy
Posted 13 Years Ago
Posts: 1.6K, Visits: 5.2K
They made 332's for FE's with 330 stroke and also in Lincoln style Y blocks as a heavy duty truck motor. Which style motor is it from, I think is what he is asking?
55 Vicky & customline
Gary
Posted 13 Years Ago
Thanks for clearing up the question.  I purchased this crank sight unseen as a 312 but machine shop said 332.  I do not know if this is the FE or not.  It has numbers C56303A stamped on the flywheel flange and numbers 5750174 cast on one of the throws. Please take a look on eBay, item number 110822707959, several photos.  Any help will be greatly appreciated.
Thanks,
Gary
Posted 13 Years Ago
Posts: 3.7K, Visits: 323.2K
The lack of center counterweights typically indicates a forged crank.  The passenger car 332 would probably not have one, so I vote for the 332 truck engine, based on the Lincoln design as YA indicated.
Posted 13 Years Ago
I’m with John in that it looks like a LYB 302 or 332 shaft based on the pictures.  Roughly 1958 thru 1963 vintage.  If you can post the measurements for the main and rod journals, then that will help to positively identify it.
kevink1955
Posted 13 Years Ago
Posts: 236, Visits: 237.6K
Byt it's got a C5 part number that makes it 65 or later. When did the production of the Lincoln Y and the truck engines end?
Gary
Posted 13 Years Ago
The crank mains measure 2 5/8", and rods are 2 1/4"  Many thanks for your input!
Gary
