reviving a 292
Posted By Taff 13 Years Ago
Taff
Posted 13 Years Ago
Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)Turbocharged (50 reputation)
Posts: 36, Visits: 100
Taff (1/15/2012)
well, i got the crank bolt out!
I got the rad, water pump and hose's etc all out of the way, dumped anopther couple of litres of diesel down through the valve train and gave her a gentle rocking. Nothing.
Not too worry, I'll keep on it, she hasn't been serviced since 1971 so I'm not suprised she's being stubborn!! On the plus side, everything that comes off looks good and serviceable
Well, it moving.
I’ve been chipping away at her since before Christmas, plugs took an age to get out and then the bores were filled with diesel. The engine oil was drained out (didn’t appear to be any nasties in there) and then the motor was filled to the brim with diesel. This was drained and replaced a a couple of times, while gently rocking the breaker bar on the crank nut. And today, while dicking about with a couple of smaller things (like you do), I gave it a gentle rock as I walked past and she moved a little. Not much, but it was movement.
An hours gentle rocking later and I have got her a quarter of a turn. I was so cold by then (it’s about zero here today and the cars in an open barn) and I gave up before I went down with frost bite! Still, it’s further than that engine has turned in about 35 years, eh?!
Cheers, Taff
1959 Ford Galaxie 2dr sedan, 292 (just woken up after a 38 year sleep!)
texasmark1
Posted 13 Years Ago
Posts: 650, Visits: 2.7K
keep at it
keep at it!
wishing you warmth from Texas... where its 65 degrees today
Mark
bird55
Posted 13 Years Ago
Posts: 1.1K, Visits: 58.8K
Glad you're making progress. Patience will pay off. It may still have broken rings and such, but you can still survive that without a wholesale rebuild if you want. But we're rooting for you that it just needs more of what your doing. I forget from your past post, Are the rocker arm assemblies off?
Taff
Posted 13 Years Ago
bird55 (2/4/2012)
nope, the rockers are still on.
items removed are as follws:-
waterpump, dynamo, starter motor.
i was considering removing the dizzy as well? but know she's turning over.....   :-)
Cheers, Taff
Taff
Posted 13 Years Ago
up to half a turn, though i broke my patented engine freeing tool ( 5ft length of 2x4 with bolts through it!) in the process. time to go back with a metal one next time
she's fighting me but she's slowly giving it up!
Cheers, Taff
Taff
Posted 13 Years Ago
refitted the strater motor today and she's now spinning over on the key for the first time since 1970's
i'll carry out a couple of oil changes and once i'm happy i have some oil pressure i'll go for a start up!
Cheers, Taff
Taff
Posted 13 Years Ago
got her started today and she runs for about 5 seconds before cutting out, which is the carb needing a complete strip and rebuild
can someone recommend a good brand of carb rebuild kit? THe RockAuto one looks to be missing a few items?
Cheers, Taff
slumlord444
Posted 13 Years Ago
Posts: 1.2K, Visits: 137.8K
If it starts and runs for 5 seconds I would double check that you have fuel pressure and fuel coming up to the carb. Had similar problem with a Mustang that had sat for many years and fuel pump was toast and had dirt and rust in fuel tank.
Taff
Posted 13 Years Ago
slumlord444 (4/7/2012)
no fuel pump fitted to it, my friend,
The original fuel pump is toast, and I have an electric fuel pump ready to be fitted. The 5 second run up was achieved using a gravity-fed temporary fuel system
Cheers, Taff
Posted 13 Years Ago
Before you run it with the Gas tank hooked up i'd drain whatever's in there and clean it out.
