Hey Steve
Posted By Eddie Paskey 15 Years Ago
Riz
Posted 15 Years Ago
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Posts: 177, Visits: 4.4K
Steve,
I think you are right just start with process of elimination. It has got to be something simple and stupid I will be sure to post the ah ha. Everyone's help has been invaluable if for anything else to have some solidarity and keep me from trading it in on a gentle used Prius. w00t
At least it will give me something to do for the winter since I just insulated the garage.
I am just going to start with the basics and get the carb cleaner out and start chasing the usual suspects KISS.....
Fuel air and spark should be easy right?
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Posted 15 Years Ago
Posts: 3.8K, Visits: 33.3K
Have you tried hooking up a vacuum gauge and see what kind of reading you are getting at idle.Sometimes helpful in finding problem.
Riz
Posted 15 Years Ago
Just arranged to borrow a gage this week my last one got borrowed and never came home. This weekend will be spent trying to eliminate any possible vac leaks.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Riz
Posted 14 Years Ago
Turns out I found the leak in the hard line tucked under the hold down. It was just a small crack but I am sure it widened when it got hot. Vac problem solved. PCV now stays quiet. So i took her out for a spin. Trans did not bog and idle only dropped about 150 from park to drive so easy idle adjustment to split the difference.
Now the bad news is that I took her out on the highway and there was a little vibration above 3000 rpm. Took it home and put the timing light to it and it looks like the timing set is skipping a little at higher rpm. So looks like the next project is a new timing set (for all I know this one is orig. might as well throw in a hotter cam if I have to get in there.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
GREENBIRD56
Posted 14 Years Ago
Posts: 1.7K, Visits: 102.7K
Axial travel of a distributor shaft will cause a "jumping" signal as the helical drive gear twists the shaft ever so slightly as it moves up and down. Shim kits are around that will take up the endplay a bit if you find that is what is happening. Requires pulling the distributor out of the block and checking the clearance of the stop ring pinned under the main body.
A slipped or slipping outer ring on a damper will move the TDC mark slightly from the initial position - but I haven't seen one that moved around while you were watching.
The valve train might have a cylinder with differing lash - have you gone through the drill of setting all of the valve lash?
Riz
Posted 14 Years Ago
Ok I was wondering how it went from decent timing but not optimal to skipping junk. Went to double check and it turns out the lead was sliding too close to the number 2 lead and picking up that signal of course it would be showing incorrect. I held it closer to the plug and wow the timing was no longer slipping. Set back to 12* and decided to get a beer and leave it alone for a few days. Thanks to everyone for the help, I am an idiot.
I am telling you I want to kick myself in the butt and will stand ready to be made fun of.
Still a few tuning tweaks to be done, but apparently I am in no mental shape to do it.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
