Posts: 2.0K,
Visits: 130.9K
Anyone know if the fabrication companies that sell ready made Ford frames have a Y block motor mount option? or has this always been a pure custom install from the start? I have access to a good 34 Ford body for a good price, considering purchasing a ready made frame to make my task a little easier. Any suggestions? Dan
Posts: 3.3K,
Visits: 238.8K
Daniel: I'm not aware of anyone making a frame setup directly setup for a Y-Block, however someone else may no better. But, you might want to buy that body quickly before someone else finds out about it, buys it & puts another da_n SBC in it! Good, 73 year old 34 Ford bodies are scarce!
Last Active: 20 minutes ago
Posts: 7.5K,
Visits: 205.8K
If inquiring about motor mounts to the frame companies, you might request if Fe engine mounts (390, 427, 428) are available as the pre-1964 models will interchange with the Y-Block in most cases.
Posts: 2.0K,
Visits: 130.9K
thanks Ted - why didn't I think of that? I already use an FE starter!
Visits: 1.5K
have a y in my 32 cpe. made my own mounts, be happy to post a pic if i can get it to work.
