Fordomatic Question
Posted By ALL AMERICAN RACER 14 Years Ago
ALL AMERICAN RACER
Posted 14 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Posts: 37, Visits: 101
what's the tube on passenger side do?
it's almost like a breather tube
it was in the way of bottom
tranny to belhousing bolt
Ford 292 & Fordomatic
removed from '64 F100
Posted 14 Years Ago
Last Active: 9 hours ago
Posts: 4.6K, Visits: 38.5K
Does it go up to the back of the Intake? If so its a later version of a breather tube. Chuck
Posted 14 Years Ago
Posts: 3.7K, Visits: 323.2K
Sounds like you have a mixture of parts.  You have the air cooled bellhousing, but the tube you mention is the oil tube to the radiator tank to cool the transmission fluid.  There should be a second tube fastened at the passenger side lower rear corner of the case.
ALL AMERICAN RACER
Posted 14 Years Ago
'tube' was transmission line cut off and plugged
hoosier there's 3 things on passenger side
