Quick clutch question
Posted By JPotter57 14 Years Ago
JPotter57
Posted 14 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 144, Visits: 1.2K
Will an 11 inch clutch fit in a '57 Ford car bellhousing? I have both a 10 and 11" clutch, both are 3" tall, seem to fit in the bell, but I didnt try the fit with the fork yet. I have both flywheels and they are the same just drilled for their respective clutches. If I can use an 11", I'd rather do that....
James Potter
`57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
Posted 14 Years Ago
Yes, you can use a 10 inch or 11 inch clutch disc assembly in a stock y-block bellhousing. As you stated, you'll have to change flywheels because the pressure plate bolt pattern is different for the 10 inch pressure plate than it is for the 11 inch.
I'm not sure if the throw-out bearing is different for the 10 inch pressure plate than for the 11 inch. In the 50s Fords, FoMoCo used Long style pressure plates for both assemblies.
Hope this helps. Smile
Regards,
LON
Posted 14 Years Ago
Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)
Posts: 523, Visits: 3.7K
I had my stock flywheel drilled at a machine shop to suit an 11 inch clutch .That way I could use either 10 or 11 inch clutch .Sure beats changing flywheels all the time .I used a stock throwout bearing when I bolted up a Top Loader gearbox .Totally a different car to drive with a 4 speed .
Lon
yblocksdownunder
slumlord444
Posted 14 Years Ago
Last Active: 14 hours ago
Posts: 1.2K, Visits: 137.8K
While we are talking clutches, replaced my long style clutch in the T-Bird with a diaphram type replacement 11" for a 390 pickup. Less pedal pressure and much more plesant to drive.
gekko13
Posted 14 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 2.6K
Diaphragm pressure plates do generally have a softer pedal feel but they have draw backs as well.  The travel or rate at which they take hold is not linear.  This sometimes results in an abrupt lock up or chatter.  Also, the Belleville (sp.?) spring that provides the clamping force can over-center and fail to release at high rpm.  Imagine running through the gears, stepping on the clutch pedal, banging gears and then when you release pressure on the clutch pedal- it sticks to the floor!  This can be a bit distracting.  The Long style pressure plate does not have any of those characteristics.  I would be careful using a stock type flywheel.  They can and do come apart with unpleasant results.
JPotter57
Posted 14 Years Ago
Advice taken on the flywheel. The Y that is currently going in my Custom is only a stock 292, will use the stock flywheel while I build my 312. I am planning on a Quicktime bell and billet flywheel for it. This 292 is just to get it running, and fabricate all the pieces for it, like my T-pan, headers, etc. I will drive it around a bit, though being a stock `63 (low compression) motor, will probably be a bit of a dog. Once I get started on my 312, I hope to be able to heat it up a lot, I want a set of Mummert's heads, but will have to start saving now for those, lol. I'm only aiming for around 400 hp, and with enough compression, building one like Glen's, I could hit pretty close to that with my G heads. My 312 is still in the planning stages now, I pretty much just want to drive my `57; I've had it 5 years. When I got it, hadnt been driven since `67.
James Potter
`57 Custom Tudor
junkyardjeff
Posted 14 Years Ago
Posts: 813, Visits: 3.4K
When I got a new clutch for my 65 galaxie the shop gave me a diaphram pressure plate which required much more effort to push in and a friend had the same issues in his 64 and when we put a new clutch in it he went back with the long style pressure plate and it was much easier to push in so no more diaphram pressure plates for me.
slumlord444
Posted 14 Years Ago
My experience was that the Diaphram clutch had less peddle pressure and was easier to drive and shift. I do not have a clue as to we would have opposite experiences.
John Mummert
Posted 14 Years Ago
Posts: 913, Visits: 7.5K
There are different spring thicknesses for diaphragm pressure plates. If the P.P. has more clamping force it will be harder to push the pedal.
In the dim past I put a heavy duty diaphragm in a scrub and it was terrible to drive.
Make sure you have the clutch fork correctly installed on the pivot bracket in the bellhousing. If incorrect it can be very hard to push the pedal.
All new vehicles have diaphragm P.P.'s so I guess they're okay.
If the pedal sticks to the floor the pressure plate is probably being traveled too far. Also, you adjust the spring tension on the assist spring under the dash.
If you over travel a Long style they will re-engage.
http://ford-y-block.com
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
slumlord444 (11/5/2011)
I agree with you, i have 2 yblock 4 speed cars both with diaphram p/plates and are firm but easy on the leg, and these dia p/plates are known in the world as gentler to use. Smile
 Down Under, Australia
