Gettin the T Bird to "Hook"
Posted By Oldmics 14 Years Ago
Oldmics
Posted 14 Years Ago
Posts: 710, Visits: 78.1K
Any of you hard runnin T Bird folks want to let a newbie in on what your rear suspension mods are to get the car to launch.
Lookin to break stuff Tongue
Oldmics
BIGREDTODD
Posted 14 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
Oldmics (10/27/2011)
Oldmics
What's the problem(s) your having? Wheelspin, axle hop, or?
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
Oldmics
Posted 14 Years Ago
Havent dropped the clutch with serious tires as of yet.
Just already know the stock 9 inch leaf spring setup will need help.
Just fishin to see what the fast guys are doing.
Oldmics
speedpro56
Posted 14 Years Ago
Posts: 1.3K, Visits: 9.2K
You will need traction locs of some sort to keep the rear springs from binding and causing wheel hop. I'm using traction masters on my bird and they seem to work well. Cal tracs are said to be better but need modifications off the frame to work, I believe Vic uses them on his 55 bird. Chime in Vic.
-Gary Burnette-
Vic Correnti
Posted 14 Years Ago
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.3K
I do use the Cal Tracs as Gary said on my 55 bird. I had to make the spring pocket 1/4/ inch wider at the front of the leaf springs. I am thinking that the 56 &57 birds have the wider springs and spring pocket already. The Cal Tracks made one of my best improvements at the track.
Posted 14 Years Ago
Just look at his picture. You don't need any more proof than that. Cal tracs work.
Oldmics
Posted 14 Years Ago
So what kinda (rear) tire size will fit under the Baby Birds.
Vic looks like a 9X30 ???
Oldmics
speedpro56
Posted 14 Years Ago
225/70/15s for street.
235/60/15s for street and strip no skirts( drag radials DOT ).
225/50/15s street and strip with the lower profiles 50 and 60 you get a bigger foot print ( drag radials DOT ).
These drag radials are not ment for much highway use, only to drive to the track if it's not very far and after alittle fun....drive homeBigGrin
These tires will pull the front tires off the groung with enough power. I can sell you the 225/50/15s if interested. Thet are 24" tall and made two passes to see if there was a difference between the others and there wasn't.
-Gary Burnette-
Vic Correnti
Posted 14 Years Ago
I replaced my stock housing with a 1958 Ford 9 inch so I had to narrow it 1 inch on each side then ordered the rim offset wheels that would center the tire and miss the leaf spring and the flange on the fender. I had G 60 x 15 street tires on it at that time. I am now using Hoosier Quick Time Pro's 26 x 9.5 x 14 that are DOT approved. I have heard that the drag radials don't perform as well on a stick car as they do on an automatic car. Gary, what have you heard?
speedpro56
Posted 14 Years Ago
Not much Vic, I'm listening???? to hear what you have to say. How are your DOTs doing at this time compaired to the slicks ?
-Gary Burnette-
