Will someone tell me how to operate the overdrive on my 56 customline?
Posted By Big6ft6 15 Years Ago
Will someone tell me how to operate the overdrive on my 56 customline?...
ejstith
Posted 14 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 494, Visits: 1.0K
One thing I didn't see mentioned here is when parking make sure it's either in reverse or the parking brake is on or the overdrive is disengaged (lever out). Otherwise it will roll away if on a hill.... Also if the governor is bypassed and the solenoid is operated with a switch if one stops in overdrive the car won't go into reverse until the solenoid is disengaged.
E.J. in Havana FL
DANIEL TINDER
Posted 14 Years Ago
Posts: 1.8K, Visits: 154.5K
ejstith (11/8/2011)
When I ever get my T-85 in mine I'm going to bypass the governor & put a switch to the solenoid & just operate the overdrive with that. I had a '57 back in the day & did it that way.
One advantage to using a switch instead of the governor is slick-shift freewheeling around the city at higher speeds. Also saves wear & tear since the OD isn't constantly kicking in & out. But, wouldn't want to drive in Frisco without compression braking.
6 VOLTS/POS. GRD. NW INDIANA
ejstith
Posted 14 Years Ago
ejstith (11/8/2011)
And that's exactly what I did. 12V battery to relay, switch on the shift lever to the relay & 12V to the solenoid & solenoid grounded to the solenoid mounting bolt. Flip the switch OD on. Flip it the other way OD off.
E.J. in Havana FL
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
Big6ft6 (9/27/2011)
Cool! Thanks Jim
Nate, did you resolve hard brake pedal problem and if so, how? regards bill. Smile
 Down Under, Australia
ejstith
Posted 15 Years Ago
E.J. in Havana FL
Frankenstein57
Posted 15 Years Ago
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
Nate, my 58 ranchero came with a fresh 292 and a 3-speed OD. This car never came with that trans in it, so I had no wiring or kick down switch. After some advice I got on this forum, I wired the OD solenoid to a lighted switch on the dash. It works well, after the car is warmed up I just leave it on, (3.89 gear) I need to adjust my lockout cable linkage, doesn't pull out enough.
thanks, Mark
Big6ft6
Posted 15 Years Ago
Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)
Posts: 241, Visits: 347
Doug, what do you mean by the "cable slipping" at the tranny lever?  Do you mean the dash pull out cable that locks out the overdrive?
I have to look back at the wiring diagram to see where the ground wire comes from the governor to the relay, the switch is an inruiging idea.
Nate - Madison, Wisconsin
56 Ford Customline Sedan
DualQuad312
Posted 15 Years Ago
Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)Supercharged (189 reputation)
Posts: 91, Visits: 776
Hi,
 Saw the posting on O.D troublshooting and thought I'd comment....The gentleman who mentioned letting off the acc, pedal at above 27 mph is correct...you can get o.d. in all three gears if you wanted to....In actuality you have a 6 speed manuel transmission.... I had my 57 out the other day and I, was able to get O.D. in first gear with no trouble.....Letting off the pedal when your above 27-28 mph is key....assuming your speedo is reading correctly...Lol...You should be able to hear the solenoide click in and at around the 28mph. point.....  Your not alone when I first put an O.D. trans. in my Ranchero I didn't know how it worked either....Nor did I know how to get it to work....
Happy motoring
Jeff
Doug T
Posted 15 Years Ago
Posts: 563, Visits: 2.6K
One thing that may be difficult to diagnose is the governor. I have seen a few with the bronze contact corroded through which makes them not function at all. This means nothing will happen at 27 mph because the ground to the relay isn't made. You can put a switched grounded jumper the relay ground terminal and then turn the relay on manually at a speed above 27mph.
Another thing to look for is the cable slipping on the trany lever so that full engagement is not made.
The gearset is likely to be OK, most OD problems are outside the trany.
Overdrive is one of life's good things, running down the highway and dropping into OD just feels good.
Doug T
Jimz Bird
Posted 15 Years Ago
Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)Supercharged (221 reputation)
Posts: 118, Visits: 7.9K
Nate:
That's OK - Your a young guy so you have plenty of time to get it back to original.Wink You are doing a good job already. I enjoy reading of your progress and your movie was cool.BigGrin
We are in good company since John had one the same color as ours.
John:
Ahhh, That was a Real Mean Green - I am kind of a "Poser" now. But one of my projects when I get back is to put on a set of trips.Cool
Jim
Norfolk, VA
http://www.y-blocksforever.com/forums/Uploads/Images/9637da2e-2f28-4c4a-8dea-1636.jpg
"MABLE"
1956 Thunderbird Green / Brown Interior (ZE-XG)
"MEAN GREEN"
1956 Mainline (FG-BE)
