Will someone tell me how to operate the overdrive on my 56 customline?
Posted By Big6ft6 15 Years Ago
Will someone tell me how to operate the overdrive on my 56 customline?...
ejstith
Posted 14 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 494, Visits: 1.0K
ejstith (11/8/2011)
When I ever get my T-85 in mine I'm going to bypass the governor & put a switch to the solenoid & just operate the overdrive with that. I had a '57 back in the day & did it that way.
And that's exactly what I did. 12V battery to relay, switch on the shift lever to the relay & 12V to the solenoid & solenoid grounded to the solenoid mounting bolt. Flip the switch OD on. Flip it the other way OD off.
E.J. in Havana FL
DANIEL TINDER
Posted 14 Years Ago
Last Active: 4 hours ago
Posts: 1.8K, Visits: 154.5K
ejstith (11/8/2011)
One advantage to using a switch instead of the governor is slick-shift freewheeling around the city at higher speeds. Also saves wear & tear since the OD isn't constantly kicking in & out. But, wouldn't want to drive in Frisco without compression braking.
6 VOLTS/POS. GRD. NW INDIANA
ejstith
Posted 14 Years Ago
One thing I didn't see mentioned here is when parking make sure it's either in reverse or the parking brake is on or the overdrive is disengaged (lever out). Otherwise it will roll away if on a hill.... Also if the governor is bypassed and the solenoid is operated with a switch if one stops in overdrive the car won't go into reverse until the solenoid is disengaged.
E.J. in Havana FL
