Blown YBlock
Posted By paul2748 18 Years Ago
Posted 18 Years Ago
Posts: 3.6K, Visits: 497.7K
Found this on the HAMB - supposedly from NZ
Moz
Posted 18 Years Ago
Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)
Posts: 533, Visits: 3.7K
thats an awsome looking engine how the hell does he see to drive.
moz.
moz. geelong victoria australia.
graduate 1980, bus, truck, car, hot rod, boat, submarine, hovercraft, hydrafoil, firetruck, mobile home, jet, helicopter, cruise ship, motorcycle, bicycle, santa's sleigh, clock, alloy bullbar, alloy fuel tank, lens, dr who's tardis, matter - anti matter warp drive buffer & y-block lover
Posted 18 Years Ago
Posts: 4.6K, Visits: 38.4K
You peek around the blower. Actually that problem caused a lot of problems in a lot of states. Many don't allow it. Chuck
GREENBIRD56
Posted 18 Years Ago
Posts: 1.7K, Visits: 102.7K
Which makes me want to ask - why don't more people use the little 144 series Weiand  blowers? I've seen several, on shoebox Chevies and pickups with a little more room under the hood - seems like an ideal Y-block accessory to me. Weiand used to sell the small block Ford version pretty cheap and I've looked them over several times. What sort of surgery do you suppose would be required to put a modified four barrel manifold under it? Even the old teapot "A" manifold (which you can usually get pretty easily) would work when the pressure starts to rise.
GREENBIRD56
Posted 18 Years Ago
This is the Weiand blower I've been looking at for ideas .......
This one is for a Chebbie - the small block Ford units driveshaft is offset to clear the front mount distributor. The mounting adapter for the blower to the intake manifold is subject to invention - needs to place the snout in the right spot to create the proper pulley alignment. One really nice feature is that the carb mount is directly on the body of the blower. I have seen pictures of one that had two sidedraft Webers fitted to get the profile down. The blower housing itself is about 1/2 to 2/3 the height of a GMC style unit.
The only way to get this thing on my T-bird is to leave the hood off - which is a time honored tradition with Ford roadsters anyway!!! But it might fit nice on a fifties sedan...........
Pete's Panel
Posted 18 Years Ago
Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)
Posts: 129, Visits: 958
Yeah,  would be magic in an F-series too, especially if it was in mine!!
Pete, one of the Aussie mob.Hehe Beechworth, Victoria60 F100 Panel Van, Y-block. 65 Galaxie Country Sedan 390
Glen Henderson
Posted 18 Years Ago
Posts: 1.4K, Visits: 7.5K
A fab'ed intake or a set of Ted's scrub adapters and it would work. Looks great, what about a cheap fiberglass  hood for the bird with a cutout for the blower. Keep the orginal and it would be easy to put it back stock if you ever wanted to.
Glen Henderson
Freedom is not Free
Letohatchee, AL
pcmenten
Posted 18 Years Ago
Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)
Posts: 375, Visits: 1.1K
I think an Offenhauser 3x2 intake would make a good starting point for a blower manifold. Either cut the top open and weld in a new top, or cut the dividers between the throttle openings and use the existing top.
Best regards,
Paul Menten
Meridian, Idaho
