Visits: 206.1K
Here are pics of the 1956 (top pic) and 1957 (lower pic) manifolds. The most obvious difference is at the carburetor flange. ’56 manifolds have four holes while the ’57 manifolds have the kidney shaped openings.
Here’s an updated list with Slumlords manifolds added to the list. Looks like 49 manifolds not counting the easyissy manifold that the date was unclear on. It’s not on the list yet. 10-15-56 (JH) 12-5 (JH & RH), 12-6 (RF & Marc), 12-13 (JH), 12-14 (EP & Ted), 12-17 (TD), 12-21 (Ted), 12-28 (JH) 1-3 (JH from Ebay), 1-9 (DK & NoShortcuts), 1-11 (RG), 1-18 (JH), 1-22 (Genuinerod & Ted) 2-4 (JH), 2-7 (JH from Ebay & SL444), 2-18 (JH & SL444), 2-28 (EP & JH), 3-6 (JH), 3-7 (JH), 3-8 (JH), 3-13 (EP & JH), 3-26 (Mike), 3-29 (EP & JH & Ted) 4-3 (JH), 4-11 (SL444) 5-8 (JH from Ebay), 5-10 (EBay), 5-28-57 (fakirone) 6-3 (JH), 6-5-57 (Ted), 6-6-57 (Flatrod & JH), 6-10 (JH), 6-11 (Robs36 &Robs36) No date (CL & EBay & SL44)
Visits: 323.8K
Ted, interesting '56 manifold. My '56 manifold has flat carb mounting flanges, no cast depressions as your picture shows. Also, the casting number on mine is on the bottom of the manifold on the water passage part of the casting.
Visits: 4.5K
Ted I have been looking for that style of 56 manifold for a while now. Its only the second one that I have seen with the part# on the topside.Goes to prove that there were two different runs of the 56 manifolds Like Hooser said most of them are cast with the part# on the bottom. If that manifold is for sale OR if you want to swap me for a bottom cast 56 style manifold - please let me know. Thanks Oldmics@Yahoo.com
Visits: 2.4K
Is there any performance difference between the 56 & 57 manifolds? Thanks Jim
Last Active: 5 Months Ago
Visits: 137.8K
Prety sure I have one if you are interested.
Visits: 2.4K
Hi Slumlord If you were referring to me re the manifold, I have one, but had no idea if there was a difference. Now that I know my 57 type makes an additional 50+ Hp, I'm going to use it :-) Thanks Jim
Visits: 137.8K
I was refering to Oldcomics2. Unfortunately what I had was not the one he was looking for.
Visits: 137.8K
Got a question while we are discussing manifolds. I have a '56 manifold that has been modified by grinding out the divider so it looks like the kidney shape of the '57 manifold. I've been told that this has been apparently done a lot and signifantly lowers the price on these. How does affect the performance?
Visits: 206.1K
