Visits: 137.8K
Will the '57 T-Bird 14" wheels fit on the Lincoln disk brake front hubs?
Visits: 106.5K
You will to use the Granada/ Versilles Lincoln 14 wheels with disc brakes. The inside of the stock t-bird wheel will hit the caliper. Just grab the wheels off the donar car. The 14 disc brake rims where used on a bunch of fords all through the 70's Should be easy to find. There were many different Back spacing on different models so make sure you find a set that matches.
Pat Fleischman
Visits: 1.2K
Couple more Versallies comments. The spindles do lower the front end a couple of inches, when combined with Aerostar springs its about 4 inches. Also, the stock lower ball joint does fit but it sticks through too much for the castle nut to line up with the hole. I used a 5/8 inch spacer to get the nut where it should be. Later, Timbo
Last Active: 6 days ago
Posts: 1.9K,
Visits: 195.0K
Again, a bit off topic, but if you're now talking about 'birds, the Aerostar springs raised mine about a 1/2 inch. I'd like to tell you how much it settled, but I changed the heads to alum. right after I put them in. It looks about right now, so I got lucky. There's a post giving how tall my original springs were, as I didn't know if they'd been cut. Best $79 I ever spent on a front end.
Visits: 1.3K
What other cars would work? The lincolns are not easy to find and so are the granadas would the mustang or comet just wondering if they would fit .And what years? Thanks....
Visits: 891
The width from spring perch centerbolt to centerbolt, was the same on my 57 and the Versailles
thanks, Mark
Last Active: 14 Years Ago
Visits: 1
What other automobiles would work? The lincolns are not available and so are the granadas would the honda ford mustang or comet just considering if they would fit. Car Mats
