How to remove oil pick up tube and grommet from y block oil pan
Posted By 56 ford custom 14 Years Ago
56 ford custom
Posted 14 Years Ago
Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)
Posts: 217, Visits: 1.0K
I cant seem to figure out how to get the grommet off. its the grommet that slides into the oil pump. There is a little washer on each side of the grommet and they are all chewed up from me trying to get it off. Any suggestions?
Fomoco Low Life
Teros292
Posted 14 Years Ago
Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)
Posts: 129, Visits: 12.3K
I once used suitable size open end wrench and hit it with hammer. That took the grommet off quite easily.
Tero from Nurmijarvi, Finland
56 Country Sedan, 61 F-100, 61 F-600, 55 F-620, 52 Mercury
YellowWing
Posted 14 Years Ago
Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)
Posts: 296, Visits: 1.8K
With washers as rough as yours I usually cut them with a pair of side cutters, then if necessary use a razor blade to slit the rubber grommet. Of course you have to have new ones when you reinstall but that's a good idea anyway. Mike
1956 Fairlane Victoria (ORREO)
Overlooking Beautiful Rimrock AZ
56 ford custom
Posted 14 Years Ago
Thanks a bunch guys. How do I know how far to push the new one onto the tube?
Fomoco Low Life
salf100
Posted 14 Years Ago
Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)
Posts: 39, Visits: 82
Who has new ones?
1964 F100 292YBlock
56 ford custom
Posted 14 Years Ago
You can get the new ones from mac's auto or prestige thunder birds
Fomoco Low Life
Posted 14 Years Ago
Posts: 4.6K, Visits: 38.5K
Just far enough to get the threads started. When you tighten the nut it will move into place and seal. I rub a bit of gasket sealer on the rubber part and on the threads of the nut when I do this. Stops seepage. Chuck
56 ford custom
Posted 14 Years Ago
Thanks moonshadow
Also the owner of the motor before me said it ran good but has sat for a while and leaked a bit. Im contemplating if I should just replace the oil and water pump?
Fomoco Low Life
Posted 14 Years Ago
They may be ok. First drain and change the oil. I would attach a manual oil pressure gauge to see true oil pressure at startup. Would probably be a good idea to take the distributor out and turn the oil pump shaft with a drill. You can use a long extension and a 1/4" socket to fit on the top of the oil pump shaft (in the distributor hole, the dizzy fits over the shaft). Tape the socket to the extension so you don't have to fish for it if you lose it. Turn then oil pump (counter clockwise)and watch the pressure gauge it should come right up. Hope for 30 to 60 lbs. Take the valve covers off and watch for the oil to start coming out at the rocker arms on both sides.
While the covers are off you can use a rubber mallet to hit the valve end of the rocker arms. They have been sitting in one position for a long time and may be frozen in place. With luck a whack will break them loose. Otherwise bent push rods are in the offing.
Now the oiling system is accounted for put the distributor back in. Check the water and oil levels and if they are ok start the motor. When it starts I would bring the idle up to about 2000 rpm by adjusting the idle screw on the carb linkage, and let it run about 20 min. Watch the oil pressure and water temp. The oil pressure should be ok if you had a gauge reading.
If the temp starts to climb over 180-190deg you may have to remove/change the thermostat. As far as the water pump is concerned you should see a problem real quick if its leaking at the weep holes or not pumping enough water. Wait for the thermostat to open though.
These are generally the basics. Some folks may recommend other additional steps but it should get you running.
Hope this helps. Chuck
56 ford custom
Posted 14 Years Ago
Moonshadow, thanks for all that info. O will be doing that real soon!
Fomoco Low Life
