292 bare block
Posted By 46yblock 14 Years Ago
46yblock
Posted 14 Years Ago
Posts: 1.2K, Visits: 7.8K
In case someone wants it:  EDB block, .060 over, crank which will probably grind to 30/30.  $85.  No wear ridge at top of cylinders.
A lightly used set of 312  .030 OS cast pistons fitted to new .003 OS pins.  Cost of fitting was $70, not including pins.  $100.SOLD                                                         I think there are some new .030 undersize mainbearings there too.  $50.00.
Truck front motor mounts.  One late model, two earlier.  The earlier are of the T-bird type, one with wide ribs around the damper and the other narrow.  $18 each.
One C1TE head, cleaned and fluxed, painted, surfaced, passenger side, seats ground, no hardened exhaust seats or valves.  $90.
1 stock reground cam.  '63 specs.  Regrind by Hapco Industries somewhere in midwest.  $35.
One set of .040 used cast pistons, $25.00.
One set of new cast .060 OS 292 pistons.  7 are Badger, make of the other one not known.  $85.00.
One set of cast .060 OS rings, new, $20.
Threaded View
