WTB G or 113 heads, SoCal
Posted By skygazer 14 Years Ago
skygazer
Posted 14 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
Looking for a clean set of ECZ-G or 5752-113 heads in Southern California.
Posted 14 Years Ago
Sky: If no results here, you might try this guy. Henaults Ent. La Grange CA. Has much Y-blk stuff. Micheal @ 209-852-2476 or e mail henaults@jps.net
skygazer
Posted 14 Years Ago
Thanks!
skygazer
Posted 14 Years Ago
PF Arcand (7/25/2011)
Henaults got back to me... no joy. I may stick with my '55 t-bird fordomatic heads, maybe with slightly bigger valves. I'm thinking these are roughly equivalent to '56 "C" heads - same compression and valves.
46yblock
Posted 14 Years Ago
Posts: 1.2K, Visits: 7.8K
I have a set of bare G heads I would sell.  Cores.  $150, plus the cost of cleaning and fluxing if that is desired, and shipping.  Heads have been milled on deck and intake surfaces sometime in their past.  Dont know exactly how much.  Havent cc'd them.  The port where the water temp sensor goes has been plugged with a brass fitting, assume it is threaded, and it was milled flush when the intake flange was milled.  Guess it is possible it could have been brazed.
skygazer
Posted 14 Years Ago
Bought a clean set of 113's off the 'bay. Thanks to Dale for delivering them!
EBird1
Posted 14 Years Ago
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 21, Visits: 158
It was nice meeting you...Hope those heads work well for you.
Dale
