Picked up my 312 yesterday
Posted By JPotter57 14 Years Ago
JPotter57
Posted 14 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 144, Visits: 1.2K
I wish I could afford the bird right now, 'cuz I want it bad, but, other priorities right now. I do plan to be at Columbus this year, watching, but 2012 I will be there with the Custom, 312 powered, hopefully not embarassing myself or the Y-block community with my 1st effort.
James Potter
`57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
ecode ragtop
Posted 14 Years Ago
Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)
Posts: 285, Visits: 3.4K
james, glad you have picked a direction for your 57, now you can buy my 55 t-bird body and drop a351 windsor in it ,it is all mocked up for that!!! Are you going to try to come to Columbus this year as a spector, you will learn at lot even with out a car. Tom
  JUST A MIDNIGHT CRUISE DOWN THUNDER ROAD!!! TOM DRUMMOND MIDWEST DIRECTOR 57 FORD INTERNATIONAL
glrbird
Posted 14 Years Ago
Last Active: 8 Months Ago
Posts: 616, Visits: 7.1K
Buy it now MSD distributer 393.88 Ebay
http://cgi.ebay.com/ebaymotors/MSD-8383-BILLET-READY-TO-RUN-FORD-Y-BLOCK-DISTRIBUTOR-_W0QQcmdZViewItemQQhashZitem5ae0459690QQitemZ390309713552QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
also royce has a stock 57 distributor and a pertronix conversion in this fire breather.
http://www.youtube.com/watch?v=j_Hpz3qPlpI
Gary Ryan San Antonio.TX.
JPotter57
Posted 14 Years Ago
That's the plan, Tim....any suggestions on the G heads? Cut down guides, valve sizes etc? I would like to use a good valve in these, are they standard lengths that are easy to get or do they have to be ordered for the Y? How about springs? I want to use a cam similar to the Isky 505, maybe one of mummerts, not sure yet, still in hunt and gather phase. I want to use either a BT or Mummert intake, I know both are equally hard to come by right now, so am keeping my eyes open. Anybody has one, drop me a line, I have cash...
Or....
What are your thoughts on multiple carbs? I know a good single 4 will usually outperform multi-carbs, but how about an Edelbrock 257, or even a stock Ford part? I have read a couple of the intake tests by Ted, and I know which one I want, but it goes back to the availability thing. I will probably for now, just go with a `57 4v intake, until I can score the Mummert or BT, preferably the Mummert.
How about distributors? I know the MSD is the hot ticket, but there seems to be a shortage of those right now, and I dont really want to pay the nearly 600 everyone wants for it. How about a Motorcraft distrib converted to Duraspark with an MSD 6AL? I can pick up a new distrib, which is a Motorcraft clone, and fit it with the Duraspark breakerplate, and go that way. I have a `63 Autolite distrib, that has a Mallory Unilite conversion fitted to it, but I have read lots of negative stuff about those...Definitely dont want to get out somewhere without at least a points distrib in the trunk in case the photocell craps out.
Finally, I am planning on running a toploader 4 speed, at least for a while, and maybe a 4.56 gear for playtime, and a 3.70 for normal driving. Any other suggestions to that end?
Like I said, I am learning on this, and will be asking questions as I think of them. Thanks in advance for the help.
James Potter
`57 Custom Tudor
mctim64
Posted 14 Years Ago
Posts: 2.4K, Visits: 5.0K
Looks like you have a good start.  Let's see some pix and a build thread. Wink
JPotter57
Posted 14 Years Ago
I got it home and unloaded. It looks pretty good, so far. According to the fellow I bought it from, who is alledgedly the second owner, it has not been apart, and only has 97000 showing, and should be standard bore, albeit with a good bit of wear, as it smokes. It doesnt have any rod or piston noises, or even camshaft noise, just smokes a good bit. I also picked up a nearly new clutch and pressure plate, a bellhousing, and a set of G heads, pretty sure unposted, but I dont plan on any abnormally high compression, maybe 10.5 or 11:1. I got an extra oil pan to cut up into a T-pan also. This 312 is complete, except for the teapot carb which I let him keep. Probably should have kept that, but whatever. I got a C3 distributor that has had a Mallory Unilite module and rotor added, along with a set of NEW big fat 8 mm Mallory Pro Mag wires. Hopefully, this weekend, I can get it checked out, ready to commence...I love new cool stuff.
James Potter
`57 Custom Tudor
