1960 f100/ 292 yblock
Posted By 56 ford custom 15 Years Ago
Glen Henderson
Posted 15 Years Ago
Posts: 1.4K, Visits: 7.5K
FelPro PN MS-95003, try NAPA
Glen Henderson
Freedom is not Free
Letohatchee, AL
56 ford custom
Posted 15 Years Ago
Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)
Posts: 217, Visits: 1.0K
No that part number is for the heatshield. I wont be needing those until I get the rams horns. I need to get regular exhaust manifold gaskets. Ted was actually saying not to get a certain kind because it tends to crack the manifold?
Fomoco Low Life
Posted 15 Years Ago
The regular gaskets are the ones which are more likely to crack the manifolds.
56 ford custom
Posted 15 Years Ago
Ok im sorry but im alittle confused now. Which gaskets do I need then?
Fomoco Low Life
Posted 15 Years Ago
The part number Glen posted, or use high temp rtv. Quite honestly, you probably won't have trouble with the regular gaskets for a short time and they're probably cheaper than the truck gaskets.
56 ford custom
Posted 15 Years Ago
The part number glen pisted, isnt that the heat shield?
Fomoco Low Life
Posted 15 Years Ago
That's the gasket with the shields all in one piece.
56 ford custom
Posted 15 Years Ago
The shield that comes all the way up between the valve cover and exhaust manifold? Those are supposed to be for the rams horns right? Im not going to use those till I get my rams horns.
Fomoco Low Life
Posted 15 Years Ago
Posts: 4.6K, Visits: 39.3K
Bad news is rams horns will not clear the steering box on a car. So we can't use them. Chuck
Glen Henderson
Posted 15 Years Ago
If you don't want the upper heat shields, cut them off!
Glen Henderson
Freedom is not Free
Letohatchee, AL
