By 56 ford custom - 15 Years Ago
This is alot to type so please check out my link and see if you can answer any of my questions. My nale is 56 ford custom on thehamb aswell. http://www.jalopyjournal.com/forum/showthread.php?t=592337
By Missouri Mike - 15 Years Ago
A 1960 F-100 big back window, short wide bed with a 292 V-8, it's a great truck!! I'm certainly not the one to be advising someone but I'll tell you what I was told once, it's yours do what suits you. Car shows, magazines, and trucks on the street. You'll see so much you won't need to ask anyone. No need to rush into anything take your time it looks cool as it is. Missouri Mike
I dont know where to get the spark plug and wire heat shields
 Does anyone know who is reproducing these
By Ted - 15 Years Ago
Try this past thread for info regarding the exhaust manifold heat shields that originally came on the trucks. http://forums.y-blocksforever.com/Topic5884-9-1.aspx
I checked that. Im just contemplating on using those or the car shields. Which should I use?
Try these links to other discussions regarding the use of the HD truck exhaust gaskets being used with the car and light truck exhaust manifolds. Many Y engine builds do not use the HD truck exhaust gaskets simply because many people are unaware that they were even produced. Many other builds forfeit the use of the individual spark plug shields for a variety of reasons with the #1 reason being that the original shields are in poor condition and not reusable. It’s not a show stopper if the spark plug shields are not being used. http://forums.y-blocksforever.com/Topic22328-3-2.aspx http://forums.y-blocksforever.com/Topic5648-6-1.aspx
Thanks ted, I tracked down a set of heat shields, I wont be using them until I get rams horns. So I will just get regular gaskets for now. What is the best type and brand? What I have read I dont.dont the ones that come in the rebuild kit since they tend to crack the manifolds.
56 ford custom (6/3/2011) Thanks ted, I tracked down a set of heat shields, I wont be using them until I get rams horns. So I will just get regular gaskets for now. What is the best type and brand? What I have read I dont.dont the ones that come in the rebuild kit since they tend to crack the manifolds.I’ve discontinued using the fibre backed exhaust gaskets that are available for both the FE’s and the Y engines. There were just too many issues with the exhaust manifolds cracking after awhile as a result. What I use now if not using the HD truck gaskets (which are also available for the FE engines) is a thin film of high temperature RTV on the head and exhaust manifold surface before assembling those pieces. I’ve been using the same high temperature RTV treatment in lieu of header gaskets on the race cars and that also looks to be working well.
What brand? Where can i get them?
FelPro PN MS-95003, try NAPA
No that part number is for the heatshield. I wont be needing those until I get the rams horns. I need to get regular exhaust manifold gaskets. Ted was actually saying not to get a certain kind because it tends to crack the manifold?
The regular gaskets are the ones which are more likely to crack the manifolds.
Ok im sorry but im alittle confused now. Which gaskets do I need then?
The part number Glen posted, or use high temp rtv. Quite honestly, you probably won't have trouble with the regular gaskets for a short time and they're probably cheaper than the truck gaskets.
The part number glen pisted, isnt that the heat shield?
That's the gasket with the shields all in one piece.
The shield that comes all the way up between the valve cover and exhaust manifold? Those are supposed to be for the rams horns right? Im not going to use those till I get my rams horns.
By MoonShadow - 15 Years Ago
Bad news is rams horns will not clear the steering box on a car. So we can't use them. Chuck
If you don't want the upper heat shields, cut them off!
Ok glen, I will firgure it all out. The rams horns arent for my fairlane, they are for my f100.
Sorry I missed that part! Chuck
No worries
