Last Active: 2 minutes ago
Here's a pic of the heavy duty truck exhaust manifold gaskets with the valve cover shields. I started using these upon having a rash of exhaust manifolds crack or break upon after using the fibre gaskets that were being supplied with the rebuild kits. These gaskets greatly reduced the occurence of exhaust manifolds cracking on my end. This particular pair of gaskets are FelPro P/N MS-95003 but can likely be found in other brands also The top gasket shows the side that goes toward the head while the lower gasket shows the side that is placed against the exhaust manifold itself.
46yblock
Visits: 7.8K
These gaskets were used on trucks equipped with the Rams Horn exhausts to help shield the valve cover area from the high rising manifold.
Visits: 39.4K
pcmenten
Visits: 1.1K
Thanks Ted. I'll go get some tomorrow.
Powercoating might add too much weight. But it sure would be nice to do that to reduce heat transfer.
Best regards,
Paul Menten
Meridian, Idaho
56 ford custom
Visits: 1.0K
My truck came with these but had the regular single exhaust manifolds. Should I still keep using these? If I use these do I Still need to use the other gaskets too?
Fomoco Low Life
pcmenten (7/17/2007) Powercoating might add too much weight. But it sure would be nice to do that to reduce heat transfer.
I do believe that a part of the purpose of this gasket is to promote heat transfer to better cool the manifold which in turn prevents it from cracking.
gritsngumbo
Visits: 2.2K
Ted: Are these pretty readily available? Or are the difficult to find?
Gerald Ingram aka "Gritsngumbo" Monroe, LA LITTLE RED: 64 Ford F100 Short Bed Styleside BIG RED: 63 Ford F100 Long Bed Unibody BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody BIG “UN: 63 F250 Longbed Flareside CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
gritsngumbo (6/2/2011) Ted: Are these pretty readily available? Or are the difficult to find?It’s been since the tail-end of last year since I’ve ordered any of these but the warehouse in Dallas where I get my parts was still stocking them at that time. Taking a quick look at Ebay shows several sets for sale so these appear to still be available.
56 ford custom (6/2/2011) My truck came with these but had the regular single exhaust manifolds. Should I still keep using these? If I use these do I Still need to use the other gaskets too?The HD truck exhaust gaskets are designed to sandwich between the heads and the exhaust manifolds without any additional gaskets. Using the fibre gaskets on either side of the truck gasket will prevent the prerequisite heat transfer that needs to take place between the heads and the exhaust manifolds. It’s ideally best to go with a metal to metal fit at the heads/exhaust manifolds or use the HD truck exhaust gaskets if trying to minimize exhaust manifold breakage issues. Keep in mind that all the Y car engines other than the HD trucks came from the factory without any form of exhaust gasket at the heads.
The Master Cylinder
Visits: 6.2K
Ted, what are your thoughts on the copper exhaust manifold gaskets that are available?
