How can you identify early and late 55-56 steering boxes
Posted By oldcarmark 14 Years Ago
Posted 14 Years Ago
Last Active: 5 days ago
Is there a way to identify the better 3 tooth sector shaft box by the casting # on the housing without opening up the box?I am trying to get someone who has a box for sale to tell me which box he has.
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
oldcarmark (4/25/2011)
Over here most of the 2 tooth sector boxes have a large blind adjuster lock nut that conceals the thread, the 3 roller sector just has a normal flat nut with threaded screw sticking through.Smile
 Down Under, Australia
marvh
Posted 14 Years Ago
Posts: 513, Visits: 16.7K
The sector shaft for the 2 tooth is 1.125" diameter above the spline where the pitman arm sits. The 3 tooth is 1.25" dia in the same location. The OD of the seal is proportionately larger in the 3 tooth box.
If it is a Canadian 2 tooth box most I have seen were mfg by a separator company and have AB___ number cast in the casting.
I have only seen the 3 tooth boxes in converts, crowns or the high end cars and late year cars. The customlines and mainline got the 2 tooth box. The same 3 tooth sector shaft and steering box was used in the 57's. The worm shaft length is different between a 56 and 57
marv
Posted 14 Years Ago
Hey Marvh! Its an American car.Casting # is AF 3550.I would like to get hold of a good used(?) 3 tooth box to replace my 2 tooth box which jams up once in a while.Kind of unnerving when it happens.Is that casting # any help.My engineering to part# cross reference book doesn't go back that far.
marvh
Posted 14 Years Ago
Mark
If you measure the sector shaft it will tell you if 2 tooth or 3 tooth. The 3 tooth is 1/8" larger diameter than a 2 tooth. 3 tooth should be 1 1/4" diameter. I will check the numbers on my car tomorrow as it has the 3 tooth box.
marv
DANIEL TINDER
Posted 14 Years Ago
Posts: 1.7K, Visits: 151.9K
[quote]oldcarmark (4/25/2011)
Just curious, but is the faster steering ratio on '55 birds due to the # of teeth, or some other component change in later models? Was the 3 tooth upgrade for improved strength/durability at the cost of slower steering?
6 VOLTS/POS. GRD. NW INDIANA
Posted 14 Years Ago
I'm not sure about the steering ratio situation, but 55,56 - 2 tooth boxes had durability issues. They tended to develop flat spots. A friend had a 56 club sedan years ago that had a major flat spot in the box. However, the later boxes incuding the 57s weren't ammune to that problem either, I know from experience. 1958 & later boxes are a resirculating ball design. However,they don't just bolt into earlier models. One issue is the horn design which is totally different...
Posted 14 Years Ago
There ia listing on Ebay for a completely reconditioned integral type power steering box modified to mount the same as the original 55-56 box.You have to shorten the existing upper shaft and use a coupler to join together like the later model Fords.Pricey though at $600.00 plus shipping.
skygazer
Posted 13 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
marvh (4/25/2011)
I just acquired a 3 tooth steering box from a 1957 t-bird with a 1.125" diameter sector shaft. Will post pics w/update.
Number on casting is AF-3550-A
marvh
Posted 13 Years Ago
I think you are mis-reading your vernier.
If I see correctly the dial is between the 20 and 30 and looks past what would be the 25...more close to 26 so would be the 1 inch on the slide scale plus the 0.26 on the dial so would be a total of 1.260 inches. This would be a 3 tooth shaft. Congrats on the bird part find.
Here is a pic of a 3 tooth I took this AM. The reading I got was 1.2495 which is 0.0005 under 1.25 or 1/2 thou less than 1 1/4 inches.
1.125 equals 1 1/8 inch
