CNC ported aluminumheads
Posted By John Mummert 15 Years Ago
unibodyboy
Posted 15 Years Ago
Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)
Posts: 118, Visits: 2.4K
I will buy a thermostat housing, timing cover, and water pump at the exact moment they are available. Really missed that boat the first time and I've been kicking myself ever since.
My name is Greg and I am addicted to Y's.
stuey
Posted 15 Years Ago
Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)
Last Active: 8 Months Ago
Posts: 444, Visits: 3.8K
hi
re timing cover   Duck was looking at a serpentine system which stirred the one grey cell, does a serpentine system require a reverse rotation water pump?    or is it the timing cover that gives the direction ie  the dam at the end of the outlet in the timing cover? then the question is could a timing cover be designed which had a dam both ends of the outlet that would allow you to gind/remove whichever you didn't want
or have i totally misunderstood water pump operation??
on a learning curve
stueyUnsure
Posted 15 Years Ago
Serpentine systems do not necessarily require a reverse rotation pump. It depends on just how the belt must be routed.
stuey
Posted 15 Years Ago
point taken. just that all the ones i've seen have the belt running under the pump pulley.just goes to show how blinkered i can be.
thanks for opening my eyes/mind
stueySmile
