1956 Customline 272 Motor
Posted By Ice0verlord 15 Years Ago
Ice0verlord
Posted 15 Years Ago
First Time Poster
Last Active: 15 Years Ago
Posts: 4, Visits: 14
i was wondering if i could fit a 460 motor in my car and what kind of modifications would i be looking at?
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
Ice0verlord (3/28/2011)
Might be an idea to include some details of what car you are referring to, i would think it may be beyond you. Obvious mounting points, tailshaft, shift, exhaust, I persobally have fitted them in 56 custonline sedans.Smile.
 Down Under, Australia
Ice0verlord
Posted 15 Years Ago
First Time Poster
1956 Ford Customline 272 Block
glrbird
Posted 15 Years Ago
Posts: 616, Visits: 7.1K
You will have to Fab engine mounts, trans mount, exhaust clearance, oil pan virus cross member and steering linkage, front springs to handle the added weight and shift linkage if you keep it on the column. You might need to conceder the cooling system and if it will need upgrading. Then there is the issue of the rear end, may be change to a 9 inch. You could build a nice running Y-block for that kind of money.
Gary Ryan San Antonio.TX.
Ice0verlord
Posted 15 Years Ago
First Time Poster
ouch i really didnt want to have to mess with a cross member.. now i am wondering what motor i can fit that will not have to have to many adjustments
aussiebill
Posted 15 Years Ago
Ice0verlord (3/29/2011)
Y BLOCK!BigGrin
rick55
Posted 15 Years Ago
Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)
Posts: 550, Visits: 4.4K
As Bill says the Y Block should always be first choice. My experience is that the Cleveland 351 with a C4 is the next best. There is very little modification/fabrication necessary with this swap. It requires an adaptor to fit the Cleveland engine mounts to the original mounting point, a 4" plate between the gearbox mount and the existing cross member, tailshaft mod, exhaust and away you go.
Having said that Y Block is still the easiest and best.
Hope that gives you some insight.
Regards
Rick - West Australia
Ice0verlord
Posted 15 Years Ago
First Time Poster
i know i want a y block but what y block XD theres different ones
thats the reason i came to this forum cuz its y-blocksforever.com =p
PWH42
Posted 15 Years Ago
Posts: 854, Visits: 6.0K
Any of the Y blocks(272,292,312) are a bolt in for your car.An engine out of a truck or a T-Bird will have a front motor mount that you won't use,but the engine is the same as a car engine.The only Ys that it's best to stay away from are the 54 239 and 256 models.They are good engines,but have some differences from the later models that make them a little less desirable.
Paul,
Boonville,MO
