RB
Visits: 16.7K
I know I have one around here somewhere but damned if I can find it..
I think they are the same car or truck.. Anyone have one for sale?
carl
Visits: 20.6K
Do you mean the wire clip that holds the fork to the bellhousing Carl
RB
Visits: 16.7K
No I have the clip, there is a little flat piece with 2 notches in one side It is what the clutch fork pivots on
Last Active: 4 hours ago
Posts: 3.6K,
Visits: 497.7K
Didn't the truck use a ball?
The car pivots are usually riveted to the bellhousing.
aussiebill
Posts: 1.8K,
Visits: 11.4K
RB (3/14/2011) No I have the clip, there is a little flat piece with 2 notches in one side It is what the clutch fork pivots onHi royce, reason i asked for clutch fork is that the pivot bracket riveted to bellhousing is totally different to customline type fork, i see you asking about that pivot bracket, so here is pic of whats on mine and perhaps fork application. OR make angle bracket to fit customline fork? as a solution to fix. regards bill.
bla bla
RB
Visits: 16.7K
Bill, the bracket you show has 2 slots in it. The piece I am talking about is flat and sits in those slots and the fork pivots on it The clip holds the 3 parts together. You can see by the shape of your bracket that a clutch fork would not be able to pivot on it. The piece I am talking about would allow you to use a common Ford fork
aussiebill
Posts: 1.8K,
Visits: 11.4K
RB (3/14/2011) Bill, the bracket you show has 2 slots in it. The piece I am talking about is flat and sits in those slots and the fork pivots on it The clip holds the 3 parts together. You can see by the shape of your bracket that a clutch fork would not be able to pivot on it. The piece I am talking about would allow you to use a common Ford forkOK, i thought that could be so but of the 4 ford forks i have, they seem too short from that pivot point to center of the box locating hole.
Posts: 7.4K,
Visits: 205.7K
Royce. I have a stack of bellhousings in which I can remove one of those riveted clutch fork pivots from and send to you. I'm assuming we're talking about the common one which is just an angled piece about an inch high with a tab on it to hold the anti-rattle spring. I’d have to check but I believe the FE pivot is also the same. Just give the word and I’ll drop a pivot piece in the mail.
aussiebill
Posts: 1.8K,
Visits: 11.4K
Ted (3/15/2011)
Royce. I have a stack of bellhousings in which I can remove one of those riveted clutch fork pivots from and send to you. I'm assuming we're talking about the common one which is just an angled piece about an inch high with a tab on it to hold the anti-rattle spring. I’d have to check but I believe the FE pivot is also the same. Just give the word and I’ll drop a pivot piece in the mail. Ted, yes thats what i,m considering doing also, will makes things simpler.
RB
Visits: 16.7K
Ted It's a Lincoln aluminum bell and I would just as soon not mess with the backet. I can probably fab up the piece I need. Thanks tho
