Hoosier Hurricane head gasket
Posted By Hoosier Hurricane 14 Years Ago
Glen Henderson
Posted 14 Years Ago
Posts: 1.4K, Visits: 7.5K
Well good luck with this one John, you sure had your share of bad luck with head gaskets last year.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 14 Years Ago
Last Active: 10 hours ago
Posts: 3.7K, Visits: 323.2K
Well, at about 4:00 pm today I fired the Hurricane up.  Only ran it long enough to set the timing, didn't bother to put water in it.  Now I just wait 'til spring.
Posted 14 Years Ago
Glen:
Yes, they are 471.  Another reason I lean toward a block problem is that #8 cylinder has no gasket problem.  With the heads being interchangeable, #1 and #8 should be cast the same.
Glen Henderson
Posted 14 Years Ago
John are these 471 heads?
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 14 Years Ago
Oldmics:
Thanks for the thought.  I had never thought of that.  But since the engine is ready to install, I'm not inclined to pull the head and check it.  But I could check a spare head and see if that happens.
Oldmics
Posted 14 Years Ago
Posts: 710, Visits: 78.1K
Hoosier
I read where Vern showed the Ford guys that he could put a dial indicator on the head and push on the non-posted area and get the dial indicator to move showing flex in that area.
If your head (God forbid) has a crack or an air pocket in the "post",it could still flex.
Perhaps trying to Vern"s method of inspection could ascertain if there still could be a problem.
Hoosier,you absolutly have forgotten more than I will ever know about Y Blocks.My suggestion is just a different view point from something I read that might be worth a glimpse at.
I always think two heads are better than one Smile
Oldmics
Posted 14 Years Ago
Oldmics:
Yes it is, and this head is posted adjacent to the water opening that the gasket leaked into.  And the water hole in the block is adjacent to the cylinder wall, which makes it like a huge post in the block.
Oldmics
Posted 14 Years Ago
Isnt that the area where the posted heads are reinforced?
Oldmics
Daniel Jessup
Posted 14 Years Ago
Posts: 2.0K, Visits: 131.0K
John, I am about half your age, but I sure hope I am as sprY as you are when I get up to that age. And about the Y block knowledge...you have probably forgotten more than a fella like me will ever know! Tongue
Hope and pray you can be around a lot longer...
Daniel Jessup
Lancaster, California
mctim64
Posted 14 Years Ago
Posts: 2.4K, Visits: 5.0K
Good luck John!  I hope you have got it fixed.  I see a lot of heads that blow gaskets N/A with those little dips in them, it doesn't take much. Wink
