Tbird wheel/tire combination
Posted By Noob 15 Years Ago
Noob
Posted 15 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Posts: 158, Visits: 1.8K
Anybody have any thoughts, guesses, experience with the largest tire size I could fit on 16" wheels to fit in the rear wells of my `57 bird without tubbing it?  I'm a fan of tire patch, so the wider the better.
I dont know the offset of these AR Torq Thrust wheels I inherited, but mounted they appear standard compared to stock.
I'm prepared for some trial n error, but recommendations would be appreciated.
Cheers... Brian
Cylinder Index = 84
Current Experiment = `57 Tbird, Grand Rapids, Michigan
Posted 15 Years Ago
Posts: 3.7K, Visits: 323.8K
Summit (and probably others) sell a measuring devise that you bolt to your drum, adjust the arms accordingly as you roll it around your wheel opening, and check tire clearances.  Probably much better than trying various wheels and offsets.
Don Woodruff
Posted 15 Years Ago
Posts: 190, Visits: 1.6K
If you are running the skirts, bout the only thing that fits is the original wheel/tire combination.
I have 14/5.5 in wheels with Coker wide whites (basically oem section width and height) from a Crown Vic on the front of mine. These just barely clear the "A" arms.I cannot put these on the back and put the skirts on.
GREENBIRD56
Posted 15 Years Ago
Posts: 1.7K, Visits: 102.7K
I've got 225/50/16's on mine (no skirts) - you could probably go to 235's on the back with exactly the right backspace, and still have some clearance to prevent rubbing.
Hoosier is right about the careful mesurements - and you need to be a bit conservative about side clearances. Due to the sidesway of the leaf spring arrangement (and assuming no add-on "track bar") - you can get contact even though things look fine sitting in the driveway.
55Birdman
Posted 15 Years Ago
Posts: 1.0K, Visits: 4.5K
I have 205 70 15s  7 in wide all the way around. Tight in the back . Front seems ok.
55Birdman Smile  Hickory NC
Noob
Posted 15 Years Ago
Thanks, fellas... no skirts, but have track bar, so that's a helpful caution... I was leaning toward 235's, but the Summit gage/fixture could be a good investment to save me some money in trial/error.
Thumbs up... Brian
Cylinder Index = 84
Frankenstein57
Posted 15 Years Ago
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
You might try digging up old posts, someone had some current mustang wheel/tire combos on a 57 bird that looked quite nice
thanks, Mark
Frankenstein57
Posted 15 Years Ago
There it is 11 posts down in this catagory
thanks, Mark
speedpro56
Posted 15 Years Ago
Posts: 1.3K, Visits: 9.2K
The largest I've run on my 56 tbird was 245/ 50/ 16s and alittle to close for comfort but they worked. The taller I went I had to bring in the width some. 235/ 60/ 16 and currently 225/ 70/ 16s and a little more comfort in wearing my fenderskirts. I did have traction masters with all these tires and still do.
-Gary Burnette-
Posted 15 Years Ago
Posts: 1.9K, Visits: 195.0K
By coincidence,I spent yesterday going thru the old post, and also looking at the device at summit for measuring.  Like you I'm looking for a larger contact patch.  A few years ago I had Wheelsmith build me a set of 7" steel rims, I think with 5.5" of back spacing.  They fit on the back with a 9" WW pie crust cheaters, and looked cool.  drove terrible of course.  I had to "relieve" a bulge in the wheel well (for the trunk springs) a little, or they would rub there on a tight, uphill corner.  A panhard rod would also have solved the problem.  The skirts weren't even close to fitting with those tires.
Some of the earlier post also say a 2002 explorer 16x7 rim will fit front and rear, but I haven't had time to verify that.  The consensus on front backspacing seemed to be 3.75 inches, with perhaps one person saying 4", but that could have been a real low profile tire with not much bulge.  It looks to me that to get 7" rims all around, there might be more backspacing required in the back, at least to get the skirts on.
There was also some discussion about spring rates, and the use of early 90's 2wd aerostar front springs.  Anyone try that and care to post a report?
