55vickey
Visits: 6.4K
Does anyone have a 55 Ford frame diagram with the measurements from all points, Thanx, Gary
Gary, 55 Vicky, St. Germain, Wisconsin
Visits: 323.2K
Gary: I have a frame diagram for '57 Fords that I got from Joseph McGlennon, 2001 Swarts Rd., Dixon, IL 61021. This was 4-5 years ago, don't know his status now. Also don't know if he had any other years available.
Oldmics
Visits: 78.1K
The frame specs are in each of the Ford Service Specifications books .They are the little 6" X 3" phamplets that show each years specs. I have one for the 56 and 57 model years frames but there is a good possibility that the 55 model year is different.I do not have the 55 model year Ford Specifications book.  Oldmics
marvh
Visits: 16.7K
Yes the 55 frame is different than the 56 frame. The front body mount position is almost an inch different between these years. I cannot locate my books on it. If I find i will post the measurements. We used to use these for frame alignments back when.
The spec is also in one of the old Fomoco Times magazines. I don't remember the date.
marv
Oldmics
Visits: 78.1K
Here is a 55 Ford Specifications Manual on eBay currently. (I AM NOT ASSOCIATED WITH THE AUCTION) http://cgi.ebay.com/ebaymotors/1955-Ford-Service-Specifications-Manual-/150408147791?pt=Motors_Manuals_Literature&hash=item230506334f Buy It Now for $12.00 OR best offer plus $2.00 shipping.It will have your frame info in it. Oldmics
marvh
Visits: 16.7K
I found the sheets.
Do you need for a convertible or all except convertible. Convertibles have difference frame.
marv
55vickey
Visits: 6.4K
I would think all except convertible. although I've heard that the 55 vicky and the convertible were the same.
junkyardjeff
Visits: 3.4K
My very late 55 has a 56 body so I am wondering if I have a 56 frame too since they are different. marvh (1/7/2011) Yes the 55 frame is different than the 56 frame. The front body mount position is almost an inch different between these years. I cannot locate my books on it. If I find i will post the measurements. We used to use these for frame alignments back when.
The spec is also in one of the old Fomoco Times magazines. I don't remember the date. marv
marvh
Visits: 16.7K
I was looking at the diagrams and see that there is 1/4" difference between 55 and 56 frame on front body mount.
The 56 is 1/4" more forward. The second body mount is 1/8" difference between 55 and 56, again 56 is 1/8" more forward. From memory I thought it was more. There is probably enough slop in the frame holes and body holes to allow a 56 frame to be installed on a 55.
marv
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I believe the 55 shop manuals have a diagram of the frames. I do know the Vicky and convertible frames have an extra plate welded down the bottom of the frame for stiffness. Almost looks like someone added a patch down the underside of the frame but it is factory.
