And yet another prize!
Posted By mctim64 15 Years Ago
mctim64
Posted 15 Years Ago
Posts: 2.4K, Visits: 5.0K
I guess the valve covers are OK.   Wink
http://cgi.ebay.com/ebaymotors/56-FORD-THUNDERBIRD-312-Y-BLOCK-HOT-RAT-ROD-NR-/180599814069?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2a0c9677b5
Posted 15 Years Ago
Posts: 6.1K, Visits: 442.9K
Wow, people have actually bid it up that high and there's more than 5 days left! It's one of those rare 1956 '58-'59 truck t-bird 292ci 312s with the even rarer rocker oiling system. The crescent on the crank confirms it. Maybe they are bidding on it only for the distributor.
The description says the head numbers are shown but I don't see them.
PWH42
Posted 15 Years Ago
Posts: 854, Visits: 6.0K
That's a really rare Holley carb.I've never seen one that looked like that.
Paul,
Boonville,MO
Bob's 55
Posted 15 Years Ago
Posts: 287, Visits: 1.0K
The Tach drive distributor might be worth something to a purest, like the red spark plugs.
charliemccraney (12/16/2010)
Don't see "the even rarer rocker oiling system", tho.
BOB
Posted 15 Years Ago
Bob's 55 (12/16/2010)
It's only more sarcasm from me. The seller seems to think it's an important piece of info. They all have rocker oiling systems.
PWH42 (12/16/2010)
It's one of the extremely rare Holley Autolite carburetors. Only 2 were made. It occurred as a result of the great 4 barrel depression of 1957. Holley and Autolite could only make 2 barrels each so they joined forces temporarily to get through the depression and together they produced 2 4 barrel carburetors. Then the depression suddenly ended and the joint venture was terminated.
Bob's 55
Posted 15 Years Ago
Oh, I thought you were seeing one of those copper tubing setups that were so popular when your oil passages plugged up with sludge. Over my head I guess Unsure
I see he is selling the "proper water pump spacer" in another auction.
BOB
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
From here the block number looks like a 292? any thoughts.Wink
 Down Under, Australia
Posted 15 Years Ago
That block could be a 312. Whatever it is, it is not a real '56 Tbird motor. The only part I see that looks Tbird is the distributor.
PWH42
Posted 15 Years Ago
I remember that 4 barrel depression well.It got so bad that we had to resort to using 3 0r 4 and sometimes 6 2 barrels to keep everything going.
Paul,
Boonville,MO
46yblock
Posted 15 Years Ago
Posts: 1.2K, Visits: 7.8K
I like the low mileage thermostat housing, without a bypass tube.  Also it would be a good bet that the carb is a 1.12 FE carb.  Looks like it just came out of the surplus pile.
