wanted neutral switch
Posted By kansas 15 Years Ago
kansas
Posted 15 Years Ago
Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)Supercharged (337 reputation)
Posts: 167, Visits: 846
Im looking for a 57 transmission neutral switch
Posted 15 Years Ago
Suggestion-Get one for a 58 Ford with Fordomatic.Interchangeable for 55-57 switch and it will start in both park and neutral.They are on Ebay fairly regularily.As a matter of fact I watched one that ended yesterday  with starting price of $25.00 and no takers.
kansas
Posted 15 Years Ago
theres a 58 switch on ebay right now ,but it doesn't look anything like a 55-57 are you sure a 58 will work on a 55?
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
kansas (12/16/2010)
I was wondering the same thing, i might be wrong but thought the 55-56 switch bolted to bracket on side of lower column and 57-59 was on end of shift column tube and was plastic??
 Down Under, Australia
Posted 15 Years Ago
The correct 58 Ford switch looks identical to the 55-57 original switch.I dont see one on Ebay right now that is correct.I will post when I run across one.The one I see on Ebay right now is for 58-60 Thunderbird.It has to be for 58 Ford only as the 59 model does use a completely different plastic switch.
Gerry
Posted 15 Years Ago
Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)
Posts: 188, Visits: 1.9K
http://www.greensalescompany.com/   Found this.  Gerry
Lake Forest California  5th inf 77 Armor Div. VN 68/69
If you put your town and state in your signature
help might be closer than you think.
