Wanted: 55-57 T-Bird upper shaft
Posted By M_S 18 Years Ago
M_S
Posted 18 Years Ago
Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)
Posts: 39, Visits: 258
I know a few of you out there have 'birds so I figured I would post here as well as some other sites. I took my control arms in to have new bushings pressed and the shop just called and said they gauled the threads beyond repair on one of the upper shafts. I have looked through all of my parts catalogs and it seems that the shaft is not being reproduced. A check on Ebay did not prove fruitful, either.
If anyone has one, or has a lead to find one I would greatly appreciate it.
Also, the thought of having it turned and re-threaded passed through my mind but I don't think this is the greatest idea. Any other ideas on saving this one?
Posted 18 Years Ago
Posts: 3.7K, Visits: 322.6K
M S:
Possible repairs for your shaft would be having the thread area welded up, turned, and threaded.  Also, a new one could be fabricated using the old one as a sample.
I have another solution which you may be interested in.  I have a NOS shaft in what's left of the original Ford box, with the three large dished washers, two lock washers, and two nuts.  It was originally a kit Ford #B4A-3047-B, but the rubber bushings are not there.  $100 + shipping from East Central Indiana.
John
GREENBIRD56
Posted 18 Years Ago
Posts: 1.7K, Visits: 102.7K
Dennis Carpenter has the shaft you want - I think the one I bought a couple of years ago was like $40 or so. The 55/56 passenger cars used the same shaft.
