WTB - PCV setup
Posted By tarheel 15 Years Ago
tarheel
Posted 15 Years Ago
Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)
Posts: 36, Visits: 613
I want to change my '56 312 from a road draft tube setup to a pcv setup. I need the valley pan with the pcv baffle. I've thought about drilling a hole in my non-pvc valley pan and welding a baffle on it. Has anyone done this?
Larry Fuller
Posted 15 Years Ago
Larry: It has been reported here that only 63-64 trucks had a PVC setup. However, as described in PHR's 1999 Y-Blk builldup, any rear draft tube valley pan, can be altered to except a valve. A baffle mod might be needed..?
46yblock
Posted 15 Years Ago
Posts: 1.2K, Visits: 7.8K
PM sent.
lowrider
Posted 15 Years Ago
Posts: 479, Visits: 10.9K
I did it on my 57. Took an older valley pan, drilled a hole for the pvc and made a baffle for it. Wasn't a concours fabrication but it works.
