WTB - PCV setup
http://forums.y-blocksforever.com/Topic51268.aspx
By tarheel - 15 Years Ago
I want to change my '56 312 from a road draft tube setup to a pcv setup. I need the valley pan with the pcv baffle. I've thought about drilling a hole in my non-pvc valley pan and welding a baffle on it. Has anyone done this?
Larry Fuller
By PF Arcand - 15 Years Ago
Larry: It has been reported here that only 63-64 trucks had a PVC setup. However, as described in PHR's 1999 Y-Blk builldup, any rear draft tube valley pan, can be altered to except a valve. A baffle mod might be needed..?
By 46yblock - 15 Years Ago
PM sent.
By lowrider - 15 Years Ago
I did it on my 57. Took an older valley pan, drilled a hole for the pvc and made a baffle for it. Wasn't a concours fabrication but it works.
