Last Active: 15 Years Ago
Visits: 8
Hey guys... I have a damper/pulley assembly from a '55 T-Bird I would like to have rebuilt. I have taken the main bolt out, but how do i pull the damper without damaging the pulley flanges? Which tool? Thanks, DG
Visits: 7.4K
I would check with CASCO or Concours Parts. I think they have a special puller for the T-Bird damper. I have made one out of a piece of 1/2" X 1-1/4" flat bar steel, drilled a hole in it and welded a nut on it and used the drive bolt from another puller. Probably easier to buy one.
Visits: 3.8K
Where are you located? I have one of the removal tools or someone else may be near by that has one also.
57 Black Tbird 312/auto
Visits: 8
Palm Beach, FL... I'd be happy to send you a deposit and pay the freight both ways.
Visits: 7.8K
Universal damper pullers dont cost very much, less than a two way shipping charge most often. They come in handy and can be used to pull steering wheels also.
Last Active: 14 Years Ago
Visits: 405
I borrowed one from the local AutoZone, you pay up front but all the money is refunded when you return the tool.
Last Active: 8 hours ago
Visits: 322.8K
Just don't hook a universal puller on the tin sheaves of the damper. You'll destroy it. There are two slots through the damper where the special T-Bird puller fits.
Visits: 8
Thanks John... That's what I was worried about. That Tbird specific puller is about $60 bucks.
Visits: 102.7K
I made one like the one Johm Mummert described above - it took little time and no money. Worked just fine and it will get you moving along pretty quickly.
Steve Metzger Tucson, Arizona
Last Active: 4 Months Ago
Visits: 7.1K
Maybe someone could post a picture so the explanation is easy to understand?
Gary Ryan San Antonio.TX.
