Was hoping that the early ‘Bird that this engine was going into would be be together in time for Columbus. But the car was pretty far apart when I saw it two weeks before the event so I can understand it not being finished in time for Columbus.
The engine was initially ~504HP with iron heads and Blue Thunder intake and jumped to 510HP with the Mummert intake manifold. It’s a race motor with upped compression and with the same camshaft that’s in my roadster. Crowding 0.600” lift. The ‘113’ heads are fully ported and both intake manifolds that were tested were also heavily modified. Much of the piston ring and friction coating technology that went into the EMC project was also incorporated into this iron headed Y.
There will eventually be a full write up on this engine in the YBM but it’s down the road a bit. Too much other interesting stuff to write about right now.
