mctim64
Posts: 2.4K,
Visits: 5.0K
Cool Ted! Can we put it in the Brick?
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I don't think it would fall under the 260CI class your in Tim, it then may put you up against some pretty stiff competition.
Hollow Head
Posts: 1.0K,
Visits: 3.8K
BIGREDTODD (8/16/2010)
sweet music! Now all I need to do is figure out how to get is set as my ringtone Right click the link, save target as and then move that mp3 file to your phone
mctim64
Posts: 2.4K,
Visits: 5.0K
Y block Billy (8/17/2010) I don't think it would fall under the 260CI class your in Tim, it then may put you up against some pretty stiff competition.You got that right Billy! Although if I could just get 350 hp that record could be ours with ease.
Unibodyguy
Last Active: 14 Years Ago
Visits: 848
So Jim what kind of RPM's were you doing with that motor??
MichaelSandy Valley, NV
mctim64 (8/17/2010)
Cool Ted! Can we put it in the Brick?  Although not 500HP, the loaner engine is back. It’s 314 cubic inch though so I don’t know if it’s something that can be used. I’ll be putting it on the dyno after Columbus just to see exactly what it’s making as it runs much better than originally expected.
Unibodyguy (8/19/2010) So Jim what kind of RPM's were you doing with that motor??If asking about the sound clip, the engine is at 7200 rpms before bringing the throttle back to idle.
grovedawg
Visits: 622
I've now listened to it about 10 times in a row. I hope you don't mind if I convert this to a ringtone. I LOVE IT! Thanks for the post.
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
Highvoltage
Visits: 188
wow! sonunds great! what kind of conecting rods are installed on that engine?
Highvoltage (8/24/2010) wow! sonunds great! what kind of conecting rods are installed on that engine?Eagle H-Beams in that particular engine. But I do have the C2 truck rods in another engine (the aformentioned 314 incher) that was being being loaned out and was being run at 7000 rpms on a regular basis.
