Adding coolant lines to the heads?
Posted By MD55Bird 15 Years Ago
Eddie Paskey
Posted 15 Years Ago
Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)
Posts: 294, Visits: 6.1K
Hey Steve;  I'm using Casco's Fan Clutch and their Blade assembly.  It works!!!   Wayne get rid of the tin plate, see casco test aboutr it!!   have a great Weekend   God Bless  Eddie
Eddie
Lake Forest, Ca. 92630
MD55Bird
Posted 15 Years Ago
Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)
Last Active: 15 Years Ago
Posts: 13, Visits: 22
All went well yesterday. It got a bit hairy when my parents got in a bit of traffic. It was 104 deg out and the car shot up to 215 real fast. It's a good thing the traffic started moving. I'll be changing out the pulley as soon as I get the chance. Thanks for all the advice.
Wayne
Wayne
Located in Lineboro, MD
55 Retro Bird
65 Cobra FFR
69 Dart
DANIEL TINDER
Posted 15 Years Ago
Posts: 1.7K, Visits: 154.2K
GREENBIRD56 (7/23/2010) The smaller pulley has revved up the pump on my outfit (about 20%) - but it doesn't really help to spin the fan that much faster. Makes a lot of noise and I would like to re-configure and use a clutch type fan drive - next on my list.
Steve,
FYI: Smaller pulley and CASCO clutch fan is blowing a surprisingly noticeable increase in wind (over the 4-blade) though the engine compartment, even when cold and still largely freewheeling. No added noise detected.
6 VOLTS/POS. GRD. NW INDIANA
GREENBIRD56
Posted 15 Years Ago
Posts: 1.7K, Visits: 102.7K
I've managed to gather up a new Hayden Heavy Duty Fan Clutch and a six blade fan to match - but still haven't got the necessary pulley designed to put it all together. Work is interfering with my hobby.................
HT32BSX115
Posted 15 Years Ago
Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)
Posts: 452, Visits: 24.4K
Howdy,
It appears that the Casco clutch and fan are Hayden units.
I asked Hayden Tech support which clutch and fan would be good for my 292. and they told me to get either a Hayden #2710 or #2711. The Fan is a Hayden #3618 (18") 6 blade aluminum fan. I found both of them online for less than $30 each!
There's a 3619 also. (19")
I paid about $60 for them at a local auto parts store and both were in stock!! Just about everybody carries Hayden. (including Casco!)
It is absolutely imperative that you have a shroud with any fan to get adequate airflow. If you don't have one, make one.
As was indicated above, if the pump is not turning fast enough to move coolant though the engine you'll have to fix that too.
An easy way to determine if you have water flow is to use a simple Harbor Freight Infrared temp "gun"
Just "shoot" the top of the radiator or the T-stat housing and the water pump inlet to see the temp drop. (Coolant goes from top-bottom so the top should be hotter)
If there's not much temp drop at the water pump inlet, (but there is at the bottom of the radiator) then there's probably not much coolant flowing though the radiator!
You can have someone hold the rpm above idle and see what RPM the water starts flowing!
Regards,
Rick
1955 F-600/272/E4OD// Disclaimer: No animals were injured while test driving my F-600 except the ones I ran over intentionally!
This post was created using OpenSuSE Linux x64 and Firefox
2721955meteor
Posts: 927, Visits: 190.0K
agree about the shroud,and fan placement in the shroud is also critical 2/3rds of the fan should be in the shroud ,no more no less for max efficient air floe.
temp top to botem of rad usually indicated  plugged or not enough capacity of radiator. I also agree the wp spacer is bad news. my first salvage of 55 third was no engine .as well of many other issues,could not find spacer for wp,but found a dampner for bird. made a spacer for wp pulley so belts lined up.had rad serviced, cores roded,installed a fairly strong 312 i built never had a heating problem,even in the summers in victoria wher i lived at the time. temp diference of 10-15  dgrs top to botem ,means rad ia ok,But proper air flow at idel is imperative,RE proper shroud. my first bird had the shroud and rad in the runk so i was lucky , but have  loked at many birds that have 3bladed fans and no shroud. ok in the fall
