Last Active: 15 Years Ago
Visits: 2
need a 292 or 312 y-block
teddyp
Visits: 20.6K
I found a 57 312 for sale today,where are you located Carl Lynn Ohio
Posts: 1.8K,
Visits: 11.4K
teddypr2 (6/14/2010) need a 292 or 312 y-blockTeddy, as has been pointed out many times before , if you listed your area location there may be members nearby that could help. rather than answering your add and are on other side of the country. plus i think i would say please
Visits: 7.8K
Also helpful, bareblock, rebuildable long block, running long block, rebuilt engine, and so on.
Visits: 115
thanks for the info about the site i,m new here i found a 292 out of a truck it was rebuilt and is 60 over it came with a truok stick set -up and a 57 ford 4 v manifold only bad part is water got in # cyc so i think i,ll get a vavle job the head has rust on the intake valve
teddyp
