I know why a tire was rubbing
Posted By junkyardjeff 15 Years Ago
junkyardjeff
Posted 15 Years Ago
Posts: 813, Visits: 3.4K
I got Fatmans spindles on my 55 and one tire rubbed when turing,when washing it today I noticed one tire stuck out further then the other so it looks like one was made wrong.  I did some research and found disc brake kits for the original spindles so when it gets a Y block it will also get the original spindles put back on.
marvh
Posted 15 Years Ago
Posts: 513, Visits: 16.7K
Check your rims, you probably have one with an incorrect offset. Measure the distance from the back of the rim to the hub centre and compare with other side.
Did the tire rub or the rim rub as the original 55 rims have a deeper drop inside the rim than rims designed for disc brakes.
Posted 15 Years Ago
Posts: 4.6K, Visits: 38.4K
Switch the rims side for side and see if it changes! Should be a simple way to see if it's in the wheels. Chuck in NH
junkyardjeff
Posted 15 Years Ago
I never thought of checking the rims,they could of sent me different widths and will check it out this week.
