Ted (5/28/2010) Varying the lash more than just a little bit beyond what’s recommended can do more harm than good in many instances so unless you know exactly what the lobe profile looks like on the opening ramp, it’s best to stick with the manufacturers recommendation at least during break-in.
I see. While increased lash would reduce total lift, thereby reducing open spring pressure and surface stress on cam/lifter, it would also speed up opening (jerk) and increase impact on the ramp. Compromise between either extreme seems indicated.
6 VOLTS/POS. GRD. NW INDIANA
