New Tbird owner what changes do I make?
Posted By rexbd 19 Years Ago
M_S
Posted 19 Years Ago
Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)
Last Active: 14 Years Ago
Posts: 39, Visits: 258
55birdman,
Yours looks just the opposite of mine (red/black).
What size tire/wheel/offset are you running and do you have a rubbing problem.
what have you decided to do about your trans (you mentioned an upgrade)
55Birdman
Posted 19 Years Ago
Posts: 1.0K, Visits: 4.5K
MS I have  215 70 15in tires. dont remember the offset. sorry. I had 235s on it but they rubbed the rear so i had to switch. I am going to put a c4 trans in it. I checked around and this one doesnt require me to tear the floor up putting in the shifter. Headers and the tranny go on this summer. I am a teacher and i need to work this summer so this will be my job. I am lookingfor discs for the rear if you know of a place to get them.  I was tryingto decide which color and I was stuck between red and black. I went to the paint store and they were out of the black so i got red. would like to put a new front end on it but that is still in thought for now. time will tell. Birds are the best SmileSmile 55bird man Earl Dagenhart
55Birdman Smile  Hickory NC
pcmenten
Posted 19 Years Ago
Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)
Posts: 375, Visits: 1.1K
I would look for a Carter WCFB for a Ford/Lincoln/Merc and keep the original intake manifold. I have such a setup with the choke mechanism attached to the manifold. Yours should look similar.
You can buy a fresh 63 distributor from Autozone, but save the old Load-o-matic dual diaphragm or sell it on eBay.
I've heard that you can make the old Ford-o-matic transmission into a 3 speed auto, but I'd recommend conversion to a FMX. The conversion uses the stock bellhousing. Another option is buying the bellhousing to convert it to an AOD or similar modern 4 speed automatic. Worth considering, but get the brakes upgraded when you do Smile.
The 6 volt system will work fine if you maintain it. They converted to 12 volt for a good reason, but the 6 volt worked for years and it can work for you. Use 0 gauge battery cables, not wimpy 4 gauge cables as found on 12 volt cars. Make good grounds all around. Remember that the coil will have the + terminal going to the distributor, not to the ignition switch. I've seen 8 volt (four cell) batteries used in 6 volt systems.
Nice car.
Best regards,
Paul Menten
Meridian, Idaho
Posted 19 Years Ago
Posts: 3.7K, Visits: 323.8K
The Fordomatic is a 3 speed.  It just takes off in 2nd gear under normal driving conditions.  You can manually select 1st by putting the shifter in LO.
John
Marc
Posted 19 Years Ago
Posts: 185, Visits: 5.5K
Earl, Master Power has a rear disc conversion for t-birds. It's a little pricey, but I think they also have a drum upgrade setup. Here's their site: www.mpbrakes.com
55Birdman
Posted 19 Years Ago
Found ECI web, rear discs 525.00 complete. Guess I got to have a yard sale. BigGrin 55birdman
M_S
Posted 19 Years Ago
Since I discovered that my bird was originally Sage, has been in the family since '58 and has relatively low miles, I have been fanatical about not cutting, drilling or harming the car in any permanent way. I have made tons of mods to the car but always using the existing holes. One that Tom mentioned was the radio, I mounted mine to the stock town & country with an aftermarket bracket that uses all original holes. I like having the glove box so this method worked out better for me and it's a great theft deterrent if nobody knows there is a stereo in the car (important because I rarely have the top up). The pics show that the radio is barely visible when peeking under the dash and cannot be seen when sitting in the car or standing next to it. The only drawback is that the face is not visible (unless the ashtray is removed). This is not a problem because I usually only listen to an ipod connected to it and all of my radio presets are easily accessed through the remote that came with the unit. Bose 151 outdoor speakers reside in the tray between the top and the trunk and 2 5" speakers are mounted under the original in-dash grill. Even the gauges you see are mounted in original holes. I can provide part #'s and more pics and details if you or anyone else is interested.
Link to pics...
