MSD distributor
Posted By Pete's Panel 17 Years Ago
Pete's Panel
Posted 17 Years Ago
Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)
Posts: 129, Visits: 958
Thinking very seriously about buying a complete replacement MSD eletronic distributor for my 292. Any reports on there good and bad points would be most welcome.
regards pete
Pete, one of the Aussie mob.Hehe Beechworth, Victoria60 F100 Panel Van, Y-block. 65 Galaxie Country Sedan 390
M_S
Posted 17 Years Ago
Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)
Posts: 39, Visits: 258
I just finished installing mine with no problems at all. It fits very tight with a Blue Thunder, but if you are careful with the dist. body position when dropping it in there is more than enough room to adjust timing before the vacuum advance hits the mani.
It uses HEI style plug boots and has a retainer that fits the buttons on the top of the boots. Very nice feature but you will need to get new wires or buy a boot kit. I had just installed new wires so, I bought MSD's boot kit for about $8. No problems with that either.
The only bad thing (a caveat really) is that it has no mechanical tach drive. I have a 'bird so this affects me, but I just got a Mooneyes tach and modified it to fit the stock 'bird bezel.
The only reason not to buy one would be the price.
M_S
NewPunkRKR
Posted 17 Years Ago
Posts: 173, Visits: 1.4K
After the stock dist. seized in the motor and the gear broke lose I went straight for the MSD.   Dropped right in, and besides me blowing a fireball out of the carb because the timing was a full rotation off when i first tried to start the motor (whoops) I haven't had any problem.  It is perfect.  There have been a couple discussions about this unit recently, and the feeback was all good if I remember correctly.  Poke around the forum and you'll probably find em. BigGrin - John
John: Lake Forest, IL
