PARTS FOR SALE
Posted By PWH42 15 Years Ago
PWH42
Posted 15 Years Ago
Posts: 854, Visits: 6.0K
I'm clearing out a lot of stuff to make room for more stuff.Here's a list of Y-block parts that need to go.
A 292 pulled from a 100,000 mile 56 that had never been worked on.I've torn it down and was going to rebuild it,but changed my mind.It could be put together with new rings and bearings and be a decent driver engine,but to be perfect it needs bored.I'll sell the entire engine for $150 or part it out.Intake and teapot,oil pan,exhaust manifolds,etc.
272 block that has only 33,000 original miles.It is in very good shape except that it has the ear below the starter where the lower right bell housing bolt threads into broken off.I ran this engine with a bolt and large flat washer there and had no problem with it.$100.
Valley cover with the provision for PCV or vent tube.It's off of a big truck and has the fitting on the oil filler pipe for the crankcase vent hose.$40.
Double groove crank dampener.The rubber is still OK and the pulley has not slipped.It has a little bit of a seal groove,but would probably seal OK.ECR-6316-B.$50.
Rear sump truck oil pan and pick-up.$50.
ECG-D heads with about 25,00 original miles.$50.
Several sets of rocker arms and shafts,valve covers intakes,generator brackets,etc.E-mail me if there's something you need.I've scrapped several engines the last couple of years and have most of the parts.
Set of .020 under Clevite rod bearings.These were installed in a short block that was never finished because I changed my mind about building that engine.$25.
I have a couple of cars to get rid of also.55 Mainline Tudor.6 cylinder 3 speed,no overdrive.Mostly complete car,but very rusty.56 Fairlane Town Sedan That's just a body shell,doors and rear end.It's a P code car so the rear end is a Dana.
All these prices are here at my house.I won't ship blocks or heads.Anything else will USPS or UPS and I'll want just what they charge me.
Paul,
Boonville,MO
Ol'ford nut
Posted 15 Years Ago
Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)
Posts: 322, Visits: 1.2K
PM sent
Ol'ford nutCentral Iowa
56 Vic w/292 & 4 spd.
awhtx
Posted 15 Years Ago
Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)
Posts: 36, Visits: 320
I have sent you a couple of e-mails and have not received a response. Send me an e-mail if you still have parts for sale. alanh@pegasusbb.com
Marc
Posted 15 Years Ago
Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)Supercharged (275 reputation)
Last Active: 7 Months Ago
Posts: 175, Visits: 5.3K
Paul, do you still have the truck oil pan & pickup?
PWH42
Posted 15 Years Ago
Yes,Marc..........I still have that pan and pickup.Interested in it?
Paul,
Boonville,MO
Marc
Posted 15 Years Ago
yep. I sent you a PM.
56 RON J
Posted 14 Years Ago
First Time Poster
Last Active: 14 Years Ago
Posts: 2, Visits: 3
do u still have the 292 motor call 336-410-4547
46yblock
Posted 14 Years Ago
Posts: 1.2K, Visits: 7.8K
If it is available I am interested in the T pot carb.  yblock46@gmail.com
64 Tim
Posted 14 Years Ago
Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)
Posts: 25, Visits: 36
I am interested in the heads.  Where are you located?
The Master Cylinder
Posted 14 Years Ago
Posts: 974, Visits: 6.2K
Yuummm, You guys do realize that your responding to an ad that is over a year old (March 16, 2010), don't you?? w00tw00t
