May have jumped the gun
Posted By Noob 15 Years Ago
Noob
Posted 15 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Posts: 158, Visits: 1.8K
Had read about the use of Aerostar springs to lower ride height on 50's Ford, though no specific reference to tbirds.
Took a leap and bought a new pair for $50 (anybody want em for $30 + UPS)
My concern is now that they stand about 4" shorter than the stock springs I removed, so my immediate reaction was... Doh!!!
Then as I was repacking the box, I noticed an advisory printed on the side that said 'replacement springs will be shorter than OEM, but are designed for proper ride height'. There was also a generic illustration showing an OEM spring being about 3 coils taller than the replacement.
I am shooting for a 1" drop with dropped spindles for disc brakes, and another 2" or so with the shorter coils, but faced with the possibility of a total 4"-5" drop (1" spindle + 3-4" coil), I'm not sure what to do.
Before I go forward to test/verify the outcome by actually installing everything, I was wondering if anybody here has attempted Aerostar coils on a `57 tbird?
Cheers... Brian
Cylinder Index = 84
Current Experiment = `57 Tbird, Grand Rapids, Michigan
MarkMontereyBay
Posted 15 Years Ago
Posts: 733, Visits: 3.8K
That is a big difference but spring rates "may" have something to do with it. I have read about this on 57 Fords but nothing definitive. The posts do specify the springs should be from a 90 Aerostar 3.0/4.0 V6 that is not AllWheelDrive. Hey, you can always take them out if they don't work. If they do work, you have blazed a hotrod trail for early Bird owners. If the springs don't work an alternative would be to cut a coil off the stock springs to use with the dropped spindles. All of this does bring up the old "bump steer" issue.
Mark Hebard
57 Black Tbird 312/auto
yehaabill
Posted 15 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guy Mark:      If you look at the coil diameter it's usually a larger
                 gauge which means it won't compress as far. A lot of
                 older ford 4x4's lift kit companies used this to make installation
                 easier without a spring compressor.
                       Can't wait to hear if it works..........
                                           Bill
Bill
Pelham,Al
