yehaabill
Visits: 1.4K
Y-guys An old friend of mine got sick all of a sudden, and had to be rushed to the E.R.! Earlier in the day he had been doing a lot of welding(he's a fabricator) and had been using brake cleaner/carb cleaner/contact cleaner/ to clean the metal before and during the welding process. We think the combination of heat and those chemicals he inhaled caused his sickness. It didn't happen at work, but several hours later. He's now in a coma and things don't look good..... Charlie/Tim please post this on any other sites(Hamb/Ford Muscle etc.) I don't go to those sites very often but I think this is important and it needs to get "out there". We're not 100% this is the cause, but we think it is..... Bill A friend googled these chemicals and and found some variations were in some of the W.W. II "gases" used in the war....
Bill Pelham,Al
Last Active: 1 hour ago
Visits: 323.1K
Bill: Sorry to hear about your friend. Hope he pulls through. While it is very possible one of the cleaners, or a combination of them, caused his illness, I wonder what it was he was trying to clean off the metal. Some type of coating? I know that galvanized metal gives of a noxious gas when you torch cut it or weld it. Was that what he was welding? Was it some type of exotic alloy? Any possibilities that you can furnish the medical people could help them treat him correctly and quickly. And thanks for the warning.
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Sorry to hear Bill, and as Hoosier says, thanks for the warning. We are always in a rush and never give it second thought to just take the quick route, if I hadn't known I may of oneday tried the same thing. When I was a little boy there was a guy on our street who rode around in a wheel chair and was mentally not here, Just about in a coma. I was informed he drank something from under the cubboard when he was a little boy that made him that way for life.
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I will print this and post it in my shop, Give copies for friends shops, others should do the same. Keep us posted on the outcome.
kidcourier
Visits: 8.8K
Guys, Just watched "Gearz" on TV on the Speed Channel and they talked about this very subject! About using brake cleaner(example:Brake-Kleen) as a cleaner before welding --stating that a chemical agent in most is Tetrachloroethylene which mixed with argon gas(mig or tig welding) causes "Phosgene Gas Poisoning"--which there's no antidote for! Even a small amount inhaled can cause long term effects such as chronic bronchitis or emphysema--also may cause damage to kidneys,liver,pancreas damage,etc. If you would like more info go to ( www.StaceyDavid.com) and click at bottom,should go to home page--at left side click on program--02-12-10 ="Welding Safety" which explains this topic. This is something everyone that does welding should read--something we all do in this hobby when using various chemicals,cleaners, paint,etc.,and who'd a thought that a simple combination could cause deadly consiquences? I hope your friend was lucky in the out come and no future problems will occur for him!Wish him well!!! KID
Daniel Jessup
Posts: 2.0K,
Visits: 130.9K
Bill, We'll be praying for your friend to pull through. If he's been fabricating for any length of time, then he is probably very aware of his surroundings and has maybe even used these chemicals before to clean his weld. Ventilation can sometimes be an issue, but that usually has immediate results. Different brands of those types of cleaning chemicals will have variations of the same chemicals, and some will have a chemical or two that others do not. Maybe he switched brands. That's why those things like MSDS paperwork can be so valuable to the doctors like Hoosier said. A sound warning for all of us.
crenwelge
Visits: 1.7K
My workman's comp made me buy a supplied air helmet 6 or 8 years ago when they saw one of my guys welding aluminum that had undercoating on the back side of it. They are expensive, but I now think it was money well spent.
Kenneth
Fredricksburg, Texas
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I have been welding metal with undercoating for years, I don't think I have come across undercoated aluminum though.
MarkMontereyBay
Visits: 3.8K
I am a former Ford dealer shop foreman. Never, ever, ever use brake clean around heat or flames. It creates a terrible poison gas. There have been innumerable discussions about this on automotive forums. Many years ago I found an apprentice spraying brake clean into carbs and running the engine to "clean" them out in the shop. He was too lazy to go to the back parts counter and get some cans of carb cleaner. It can cause devastating nerve and organ damage. Hopefully your friend will recover quickly.
Mark
57 Black Tbird 312/auto
62galxe
Visits: 2.1K
heres a article on it. chemical plants that have phosgene in the plant require phosgene detection badges and supplied air respirators to work around it. its some bad stuff. http://www.brewracingframes.com/id75.htm
Kenny Onalaska, Texas
