56 big window
Visits: 263
what are everyones thoughts on armor all for tires and vinyl? Someone told me never to use it because it causes dri-rot. Ive used for years with good results though. By the time the tires get dri rot , the're worn out and need replacing anyway.Whats a good leather conditioner
aussiebill
Posts: 1.8K,
Visits: 11.4K
I know for sure that armourall will discolor white wall tyres.
rgrove
Visits: 3.5K
Ive always had much better luck with griots garage products. Rubber cleaner & conditioner for tires, etc.... I dont let armor all anywhere near any of our cars. Too much silicone, too greasy, attracts too much dust. For plastic or vinyl dashes, I highly recommend meguires dash foam too...
Ron Grove Wauconda, IL
Posts: 3.6K,
Visits: 497.7K
For tires, I use what ever I get for free at the cruises.
Joe 5bird7
Visits: 2.8K
Guess I'm marching to a different drummer, but I've used it for 30 yrs or more, ever since the guy who did the upholstery in my bird recommended it. I've had nothing but good experience using it on vinyl (seats, dash, door panels), tires, and even rubber weather strip. In fact, using it on old hard weather strip eventually softened it up considerably as well as making it look better.......I live in a cooler, wetter climate (Wester WA) and wonder if that has anything to do with it. A friend in So Cal says it's terrible and discolored his vinal panels. ?????
shakey pete
Last Active: 14 Years Ago
Visits: 211
amoral is crap it is deadly on tires and plastic there is better stuff on the market!!! looks good for now,but over Time will cause rubber to dry out and crack same with plastic, cost me 3 new tires on my honda big Red and they where like new !!! Shakey Pete
55Birdman
Posts: 1.0K,
Visits: 4.5K
Soap and water then use some Windex. Ammonia free version
55Birdman Hickory NC
Jeffs54Merc
Visits: 469
I do upholstery and I use Eagle one Tire Wet to clean and condition the vinyl. It does a great job, a lot better the Armor All. It works great on white walls too.
Jeff Leydig Stallions Auto Interiors Stearns, Ky. USA
DANIEL TINDER
Visits: 154.2K
I quit using Armor All 30 years ago when I noticed it always turned black rubber brown. I have also heard that when used on vinyl upholstery, it dissolves the stitching. I have been using all of Meguiars' products since with no complaints. They offer so many different versions, you have to experiment quite a bit though. Also, Murphy's oil soap seems to be a safe cleaner for dirty vinyl, and won't harm stitching.
6 VOLTS/POS. GRD. NW INDIANA
stlroken
Visits: 4.8K
I have used armor all but spray on rag not directly on the dash, seats,etc. Don"t really like it. I like "Tuff-Stuf" its a large yellow and red can available at wallyworld etc and keep the vinyl moist and cleans and its cheap. Spray on the seats (vinyl) and wipe off with damp rag. Only use simple green on tires a little mequires dressing once in a while. I stick pretty much with the many mequires product and have been happy with them. Although "Mothers" is a pretty good product too.
