Unibodyguy
Visits: 848
We used to have a Taylor Forklift at my old job that was made in Mississippi and was Yblock powered. It was made in 1964.
MichaelSandy Valley, NV
Last Active: 19 minutes ago
Visits: 38.5K
How about a generic section for all other Y-Blocks? Not just boats but pumps, generators, welders, tractors (?) and anything else other than cars and trucks that has a Y-Block! Chuck in NH
Hollow Head
Posts: 1.0K,
Visits: 3.8K
Half russian?  Just joking...
Ketterbros
Visits: 2.8K
Not just yea, but bolshi da
Brother and I own/operate 1957 Ford Fairlane 312/4x2 and two 1963 Falcons 302 rollers carburated 600cfm, FE427 sitting in shed..
Hollow Head
Posts: 1.0K,
Visits: 3.8K
mctim64
Posts: 2.4K,
Visits: 5.0K
RB (2/1/2010) Tim, Do you think the in/out box might have the output shaft angled down like a V drive? The whine sure sounds like spur gears rather than a planetary.
I am gonna email the guy and see if I can't get a copy of the vid without the annoying overdubbed music
You may be right. I'd like to hear that thing without the music too.
RB
Last Active: 4 Months Ago
Visits: 16.7K
Philo
Last Active: 14 Years Ago
Visits: 489
Nice boat and a good video except for that awful 'muzak'! Would much rather hear the engine!!! Crackerbox is a racing class, they all are configured like this. Can you picture 10 or so of these racing in a chopped up lake? Hold onto that wheel!!!
FIGHT CONFORMITY!
mctim64
Posts: 2.4K,
Visits: 5.0K
I just watched it again (the video) and in the slides at the end you can see the trans. under the dash, although there must be a u-joint in this set-up because you can see the shaft pointing down from the back case and the engine does seen to be level in the frame.
Here's the guys re-decking one and Rick if you read this it is a Chris Craft and it will run a 390 FE.
mctim64
Posts: 2.4K,
Visits: 5.0K
Doug T (1/30/2010)
Hi Royce, Very cool boat. Did you notice that the engine was mounted flywheel forward and it did not have the typical marine timing chain cover? Does that mean that it has a V drive with the propeller shaft under the engine? The engine seemed to be almost level in the hull. Those guys were surely sitting up in the breeze! YES! that is very cool. Me want one too!  Doug, most of the marine engines I have worked on have the flywheel forward and run the planetary trans. with the "sun" gear attached to the snout of the crankshaft. Then direct drive strait back.
