46yblock
Visits: 7.8K
I am supposed to pick up a '62 Unibody today. The very early plan is to replace it's 223 with a 292 out of my '64 F-250. Are there some problems to be encountered that I dont know about?
Visits: 442.8K
You'll have to add a mount to the frame, at the front of the engine. Other than that it should be a bolt in.
46yblock
Visits: 7.8K
Charlie, does the bell housing and trans need to be swapped too? Both the '62 and '64 have the four speed. I was looking at the I-6 bell mounts yesterday and they appeared narrower than the V-8. What year is your truck? The '62 grill looks like yours.
Visits: 442.8K
The Y bell housing is different than the I6. I think transmission should mount to the Y bellhousing. Mine's a '61.
46yblock
Visits: 7.8K
Thanks Charlie. Paid for the truck today and got the title. Will go over tomorrow and try to start it. Luckily it is only 1 rural mile away. The '62 gives me a lot more enthusiasm than the '64 3/4 ton.
Flying Jester
Visits: 330
My friend, you and I are trying to do the same thing almost exactly, and we are probably the only two people on the internet right now who are. I am mounting a 292 from a 64 F-100 into a 63 ford Fairlane, which used to have a 170. I found that it was more sensible to use the truck transmission, as well as to notch the inside of the engine compartment at the shocks.
Google "fairlane Y-Block" to read about my struggle with closed minded people who didn't like this idea. I must say, I found people who are into 50s cars much more agreeable about this.
It also seems to make a lot of sense to use the truck's back axle, as the F series has a wheel base in between a Galaxie's and a Fairlane's (if you are using a falcon, you'll likely need a different driveshaft). What car is it, exactly?
Anyways, here's some of the work I did to research this (you must understand I originally thought I had a 312)
http://www.jalopyjournal.com/forum/showthread.php?p=4616680#post4616680
This shows how you must notch the fender wells demonstrated in a 63 (or was it 64?) Falcon, even smaller than my Fairlane.
People should not be afraid of their government, a government should be afraid of the people.
--Alan Moore
46yblock
Visits: 7.8K
Jester I think your job is a greater task than mine. The '62 is a Unibody pickup, F-100. The biggest task will be getting the body and paint in good order. The '64 small block is in great shape and the heads are being redone now. If my 312 ever becomes reality it can go into the '62 with a nice trans too. Hope the 9 inch rear is a limited slip, but will find out for sure shortly. Wouldnt it be nice if some local rat rodder wants a running I-6 . Did some searching on ebay and found parts for the 6 bangers to be CHEAP.
Visits: 442.8K
46, Since you've paid for the truck, it's probably too late but I hope you got under it and checked the cab mounts and the torque box. They tend to rust out. You will have problems if they are bad. Repairing them is not easy. All of the pieces for the torque box have to be made. Not available new. I am so fortunate that I will get to experience the replacement of both cab mounts and the torque box!
46yblock
Visits: 7.8K
Well Charlie, you probably know that I didnt... and what the hell is a torque box? Maybe luck will prevail, but thanks for the heads up. Will check it out when in the barn. Mike
bloodyknucklehill
Last Active: 14 Years Ago
Visits: 2.2K
you gonna start stock-pileing F-100's Mike?  was that the one i saw on craigslist there in Williams?
DustinSouthern Oregon Y's Guy  http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
