Replacement distributor cam
Posted By Old Y Block 15 Years Ago
Old Y Block
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 14 Years Ago
Posts: 37, Visits: 78
Can anyone tell me where I can buy a replacement distributor cam for FEK 12127, from 57 to 59 Y block V8? Distributor is mechanical as well as vacuum. I don't mind used as long as it's good.
46yblock
Posted 15 Years Ago
Posts: 1.2K, Visits: 7.8K
Is the cam/advance mech. the same as 59-64?  A friend has some new ones that he may be willing to sell.  I need to get over there and buy one myself.  The centrifugal weight slots in his units allow a max. advance of 10 dist. degrees, as opposed to some OEM units that are 13 degrees.
Old Y Block
Posted 15 Years Ago
I'm not sure, but all the catalogs say from 57 to 59. Mine is from a 59 I was told. I checked with Dennis Carpenter and they have the whole shaft with the cam included for those years. I thank you for the reply.
