BonnevilleComet
Posted By 57FordPU 17 Years Ago
57FordPU
Posted 16 Years Ago
Posts: 726, Visits: 73.6K
Hey, guys, great thread on parasitic drag from the 3rd member.  I believe this will help lots of others out there who either haven't thought about it or knew about it and didn't know what to do.  As for me, I have about a half dozen 9" housings and just about every conceivable 3rd member ratio to pick form, so, the extra cost of changing is just not in the budget (Tim will just have to make more power!).
Bill, good point about the synthetic lube.  I do run synthetic in the t-10 trans and diff now.  I think I remember Karol Miller saying that he changed the trans and diff to straight 30wt up on arrival to the events and then changed back to 90wt to drive back to Texas.  I will be changing to a T-5 and I'll have to check, but I think it uses auto trans fluid.  Perhaps there is a synthetic for that light of weight too.
The ring and pinion sets I use are NASCAR take-offs.  The sellers list them on Ebay as "polished".  When I get them they are extremely smooth and look just like chrome.  I don't know if they are just polished or have one of the treatments that have been mentioned before.
Good job on the thread guys.  Let's keep it going.............
By the way, I have spent many hours internet searching, talking to techs at IFS manufacturers like Heidts, and bending the ears of other Bonneville car builders to determine the best caster range for the Comet.  Straight axel users like 15 degrees or more (positive of course) while IFS users are all over the map (there are racers with +3 to +9).  I rolled the solid axle back 8 degrees in the race truck, but big time bumpsteer kept me from knowing if 8 degrees was enough.  The best advise for the Comet seems to be to set the rake of the frame and body at 1 percent (1" rise in 58") for best aerodynamics (NASCAR numbers), rotate the crossmember about 5 degrees positive from the  horizontal ground (not the frame) and then do the final settings with the top A arm adjustments.
Here we go.................
BurnsRacing981@gmail.com
bird55
Posted 16 Years Ago
Posts: 1.1K, Visits: 58.8K
Never said I knew very much, but wow, I just learned more about a speed trials car than I ever knew before and I didn't even ask. THANKS.
Maybe this year will be the time I can finally get out there to witness this type of racing firsthand.
57FordPU
Posted 16 Years Ago
Alan,
We'll be looking for you, and bring your work clothes.
57FordPU
Posted 16 Years Ago
By the way, I looked in the SCTA Bonneville/El Mirage rule book and found that no fender skirts were allowed (see highlighted line below).  Sure sounded like a good idea and must have been tried in the past.  I guess the rules committee decided it qualified as streamlining and felt they needed to post a rule against it.
I have forgotten to mention that we were honored in the 2009 rule book with a picture of the race truck to represent what production pickups could look like.
No caption with mention of the Y-Block, but we were pleasantly surprised just the same.
Park Olson
Posted 16 Years Ago
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 102, Visits: 1.9K
   WELLLLLL ????
57FordPU
Posted 16 Years Ago
Park, nice to hear from you...............WELLLL, what?
Park Olson
Posted 16 Years Ago
Any progress on the Comet??
57FordPU
Posted 16 Years Ago
Not much to show, family, family, family...........I know I have the priority right, but it sure feels great to get back in the shop.
Here is the Comet with front and rear suspension systems temporarily attached.  I still need to set the ride height and dial in the pre-caster for the front crossmember.  The 9" housing is narrowed and attached to springs, but the panhard bar and shock mounts are next to be fabed up.  I will post more pictures as these get finished.  I sure am looking forward to seeing that Y-Block setting in the engine bay.
57 ranchwagon
Posted 16 Years Ago
Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)
Posts: 69, Visits: 303
It sure is coming along nicely. I think we are both ready to smell some smoke. Any future plans to return to maxton?
bloodyknucklehill
Posted 16 Years Ago
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Last Active: 15 Years Ago
Posts: 242, Visits: 2.2K
Charlie the Comet is lookin good.. I might be coming down in May for El Mirage or the Eagle Field Drags so hopefully i'll get to see it in person.. Did you come up with any new info on your Turbo set-up?
Dustin
Southern Oregon Y's Guy Cool
http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
