BonnevilleComet
Posted By 57FordPU 17 Years Ago
bloodyknucklehill
Posted 17 Years Ago
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Last Active: 15 Years Ago
Posts: 242, Visits: 2.2K
i wish i could help more with the turbos.. all of my experience with them has been on fuel injected vehicles so i wouldn't have a clue how they'd perform on a carbed setup.. although the Garrett T3/T4 hybrid i had on my Subaru WRX was about the best turbo i ever owned.. that thing was awesome.. barely any lag whatsoever and held boost throughout the RPM range.. Did you decide on a twin or single turbo set-up?
Dustin
Southern Oregon Y's Guy Cool
http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
57FordPU
Posted 17 Years Ago
Posts: 726, Visits: 73.6K
Dustin,
I am still in the gathering info mode, but I would like to run twin turbos.  All the fancy math with exotic inputs seem to be geared towards finding optimum performance at all operating levels.  My simplistic mind says - I don't care about idle, off idle or mid-range responses, I just care about WOT at top end.
With that in mind, it is reported that a turbo from a late 80's T-Bird can spool up 13-15 psi on a 2.3L all the way to redline.  The Y-Block will have 4.2L and a pair of those T-Bird units would be just enough overkill to wastegate them back to the max sealing capability of the Y-Block heads.  Sounds like a start anyway...............
BurnsRacing981@gmail.com
Posted 17 Years Ago
Sounds like a talk with Reed is in order:
www.supernaturalturbo.com
mctim64
Posted 17 Years Ago
Last Active: 5 Months Ago
Posts: 2.4K, Visits: 5.0K
charliemccraney (12/14/2009)
I think Reed has already been signed on weather he likes it or not.  BigGrin
57FordPU
Posted 17 Years Ago
First I needed to make room for the Y-Block and headers by removing the shock towers.  Next will be the installation of the Mustang II front suspension with springs heavy enough to take all that weight.
Now you see them...............
Now you don't..........
Here is the donor suspension.........
Where is the instruction manual??????
It will take a while before the next up date...........do you think?
Posted 17 Years Ago
Posts: 4.6K, Visits: 39.4K
Darn, you guys are quick! Every time you post progress I want to get out to my COLD garage and do something. Anything! But alas it's too close to 0 outside and garage heat is not in the budget. Someday maybe!Doze Chuck in NH
Hollow Head
Posted 17 Years Ago
Posts: 1.0K, Visits: 3.8K
Chuck, minus 22 here at the moment! No need to go outside, just having fun watching others projects progressing. I'm sure Charlie will be at Bonneville next summer... That Comet might not BigGrin.  Thumbs up for Charlie!
mctim64
Posted 17 Years Ago
You guys need one of those Y powered wind machines to blow the warm air your way. Wink
yehaabill
Posted 17 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guy Charlie:        I saw where you're going with a 9" rear diff.
                     that you will have to narrow. You might look into an 7.5
                     or 8.8 from a Bronco II. These diff's require less power loss,
                     lighter weight,plus you may not have to "narrow" these.
                            Since your're not Drag Racing, the little 7.5
                     would proabably work well, if you can get the ratio you need.
                            Just a thought..........
                                                 Merry Christmas
                                                       Bill
Bill
Pelham,Al
bloodyknucklehill
Posted 17 Years Ago
Not to answer for charlie but im not sure a 7.5 will handle a twin turbo'd V8.. i've seen them grenaded by barely warmed up 302's swapped into 4X4 Rangers (it's off roading country hereWink) the 8.8 sounds like a viable option though, i'm not sure of the width though.. those Comet/Falcon rears are rediculously narrow (a couple inches less than 4' backing plate to backing plate if i remember right) but the Bronco II was pretty narrow.. Hmmmm.. my gears are turnin now Tongue
Dustin
